Old 05-07-2019, 07:36 PM   #15
aemravan
Well.... definitely found something not right.
The left hand intake valve does not seem to open/close while rolling the crankshaft over. About to do a quick leak down test to confirm it's not fully sealed but pretty clear that something isnt right.
The question is whether or not this is traceable back to bad recall springs or not.
Sent from my SM-N950U using Tapatalk
aemravan is offline   Reply With Quote
Old 05-07-2019, 09:00 PM   #16
maslin
Benz Tech
Drives: 2017 BRZ Premium
A tweaked valve is almost always due to a weak or broken valve spring. Or it over revved hard and floated the valves, but you would probably have more than one. And knowing this is an issue, an issue you have a pending recall for, I would go that way.
Often nothing else is damaged. Replace the valve and move on. Should be covered under the recall. It will be more work, the head will have to be removed.
Good luck!
maslin is offline   Reply With Quote
Possible recall on the 86 regarding valve spring tanner CANADA 84 11-28-2019 09:32 PM
valve spring issue? nikitopo Issues | Warranty | Recalls / TSB 1037 05-01-2019 10:55 PM
Valve Spring Failure With Forced Induction? mrhemi Forced Induction 2 03-17-2019 07:35 AM
BRZ Valve Spring Recall mrhemi Issues | Warranty | Recalls / TSB 6 03-01-2019 03:35 PM
Valve Spring Recall venturaII New England 13 02-25-2019 07:41 PM
