Old 03-14-2019, 11:34 AM   #15
VenomRush
Thee O-ri-gi-na-tor
VenomRush's Avatar
Vehicle Mileage:156xxx
Vehicle Make: 13 FR-S
Miles After Recall Performed:158900
Other work completed with recall:nothing
VenomRush is offline   Reply With Quote
Old 03-14-2019, 12:07 PM   #16
subaru
Drives: STI
you put a 158 thousand miles on your car since the recall?
I ain't 2 good at math but I'll tell you whuutt these numbers just don't compute in my science brain.
subaru is offline   Reply With Quote
Old 03-14-2019, 01:00 PM   #17
ermax
ermax's Avatar
158900 - 156xxx = ~2900 ?
Old 03-14-2019, 01:04 PM   #18
DarkSideFRS
Drives: 2013 pearl white FR-S
which socal dealership did you go to?
DarkSideFRS is offline   Reply With Quote
Old 03-14-2019, 01:16 PM   #19
158900 - 156XXX = 2YYY
Old 03-14-2019, 08:32 PM   #20
humfrz
slowly put the beaker down and back away from the fume hood -
humfrz
Old 03-15-2019, 11:14 AM   #21
VenomRush
Thee O-ri-gi-na-tor
VenomRush's Avatar
DCH Toyota of Oxnard
Old 03-15-2019, 07:08 PM   #22
ScionWolf
Drives: '13 Scion FR-S
Vehicle Mileage:115xxx
Vehicle Make:*Scion FRS
Miles After Recall Performed:2000+
Other work completed with recall: None
Side note: sound tube was not fully tightened(gasp), but more importantly there is some cosmetic damage to my alternator. Still works so whatever.
ScionWolf is offline   Reply With Quote
Old 03-17-2019, 08:17 PM   #23
oaroyale
Drives: Black BRZ
I am taking my car in on Wednesday for the recall. I just got over 40,000 miles. It seems like a lot of people are doing spark plugs, drive belt, may be even clutch and TOB. I am just wondering at 40,000, should I even look at replacing any of these? Let's say I only have to pay for parts because the engine is already. What should I replace and why?
oaroyale is offline   Reply With Quote
Old 03-17-2019, 09:53 PM   #24
Open Loop
2013 FR-S Whiteout / SSC
I have 45,000 miles and I went with the spark plugs and TOB. Unless you are really hard on the clutch it should last many more years.
Open Loop is offline   Reply With Quote
Old 03-17-2019, 10:42 PM   #25
Teseo
Drives: frs
You accumulated a lot of miles. Any problems you got on the road beside the valve spring recall? Did you changed radiator fluid
Old 03-17-2019, 11:01 PM   #26
humfrz
I would suggest you have them replace the spark plugs. Why? Because they are 2/3 wore out and they are a pain to replace when the engine is in the car.
Also, I would suggest you have them replace the TOB with the new, improved one. Why? Because, it will save replacing it on down the road.
humfrz
Old 03-18-2019, 07:22 AM   #27
oaroyale
Drives: Black BRZ
Thanks guy. I will do the spark plugs, drive belt and TOB. Quick question. How much should I expect to pay for the TOB replacement if it's being performed during the recall?
Old 03-18-2019, 11:36 AM   #28
humfrz
The part itself costs from $35 - to $50. The labor should not be charged or maybe a few dollars. Make sure they replace it with the new, improved version.
humfrz
Registry Thread: Failure After J02 Recall DarkPira7e Issues | Warranty | Recalls / TSB 489 05-26-2023 02:46 PM
TSB / Recall thread take over Sigh-on-Rice Issues | Warranty | Recalls / TSB 17 02-18-2019 11:24 PM
Value spring recall and TOB clutch issue speedy racer Issues | Warranty | Recalls / TSB 18 12-19-2018 06:33 PM
Worldwide Power Steering Issue Safety Recall nzer Issues | Warranty | Recalls / TSB 27 08-08-2016 06:14 AM
Issue updating Registry. IloveBaldEagles Site Announcements / Questions / Issues 1 03-18-2013 07:19 PM
