#15 | |
#16 | |
Benz Tech
Drives: 2017 BRZ Premium
I've been gluing engines together since 2006, still haven't blown one up. All the engines I'm around are glued together, it's normal for us. Slow down, be careful and don't blow up engines. Simple. Should also note, this stuff isn't "RTV", the nasty smelling silicone stuff everyone has seen. It dries almost hard and doesn't act like that sticky crap at all. |
#17 | |
#18 |
The car was working perfectly fine and I not kidding when I say I didn’t even drive it a quarter mile. I just felt uneasy when they emailed me asking for service records. They technically haven’t told me I’m responsible for the damage, but I’m just taking precautions.
#19 |
#20 | |
#21 | |
#22 | |
Feeling like thinking....
I agree with you re/ the presumption of facts. That's why I characterized it as a well-presented, good summation of what's been presented on the forum, and I give him credit for frequently citing his sources as primarily being forum posts and personal experience, rather than ignoring that and letting folks assume what he was writing was proven laboratory analysis rather than the anecdotal evidence that it primarily is.
Drive like everyone's life around you depends on it...
#23 | |
Drives: BRZ DGM Limited
Also, does anyone make a gasket that could be used instead of the liquid sealant that is suspected of causing the post recall failures?? |
#24 | |
Benz Tech
The engine went in to the shop with liquid gasket. It had a liquid gasket from the day a robot built it in the factory. The gasket material isn't the problem. Glued together engines (cars for that matter) aren't new. I've been around it since 2006, they've been doing it since the 80s. Not RTV, the thick stuff. It works very well. |
#25 | |
I reckon that either a Subaru bean counter figured they could save X dollars by eliminating the gaskets or they couldn't teach the robots how to put the gaskets on - ![]() humfrz |
#26 | |
There were 27,000 2013 FRSes (some with 2012 build dates) vs 12,000 BRZs so right off the bat we would see 50% fewer potential failures. The Toyota dealers had the recall kits at least a month before the Subaru ones did so they have likely done many more already. It is completely feasible that the Subaru rate could easily meet the FRS one. Now that said, the updated instructions were issued mid February (the 14th if I recall) so this should help curb some of the failures. Unfortunately we have no idea how many successful repairs have been made by either company since we only hear about the horror stories that skew the perception. We simply do not have enough data to say anything for sure.
#27 | |
The question isn't if a 1217H FIP gasket works well or not; it obviously does when a robot or top-flight mechanic who is familiar with exactly how and where it is to be applied actually does the work. The problem is that, after the fact, when robots or experienced specialists are not available to undertake this task, the human element seems to introduce failure with this stuff at a MUCH great rate than a human would simply using an old style, manufactured-for-this-specific-engine gasket. I've done one head gasket under the supervision of an experienced mechanic (which I am certainly not), a ton of valve cover gaskets, waterpumps, thermostats, etc., and have never had a gasket-related failure due to my admittedly mediocre mechanic skills and limited experience. It's pretty safe to say that if I undertook this job, I can say with certainty I'd create a grenade instantly. I can't even make a nice caulk line around a bathroom tub. Even if it were possible, the opportunity for profit in making an aftermarket gasket that serves the same function as the 1217H FIPG in our engine is probably nonexistant. On the other hand, it may very well have given a lot of these well-meaning mechanics a better chance at success.
#28 | |
| 2013 Valve Spring recall - modified (FI) engine thread | shiumai | Forced Induction | 71 | 08-11-2020 06:21 PM |
| valve spring recall/ additional work performed when engine is out | swfrs | Issues | Warranty | Recalls / TSB | 172 | 07-31-2019 12:10 AM |
| engine valve spring recall done but giant oil leak | msaikhan | Issues | Warranty | Recalls / TSB | 1 | 02-24-2019 06:18 PM |
| valve spring recall-engine oil leak | TYinhouse | Issues | Warranty | Recalls / TSB | 13 | 01-17-2019 11:09 AM |
| My engine blew up four years ago, now they recall the valve springs | Obsidiank | Issues | Warranty | Recalls / TSB | 12 | 01-02-2019 01:47 PM |
