#15 |
Does pulling up on the seat adjuster make the sound go away?
#16 |
Weight Weenie
Drives: 15 FR-S
My lumbar supports does this on occasion
#17 |
Senior Citizen Member
Good point. My 2017 developed an irritating creak/pop in the dead pedal at about 4K miles when pressure was applied during cornering. Easy fix. Pull back the carpet. Put a couple pieces of double sided tape on the metal support behind the pedal fascia (it's part of the carpeting). Done.
#18 |
Drives: 2017 86 GTS
Thanks for the replies.
I've checked under the seat and there is nothing loose or rattling about. Took out seats and re-bolted it back on tightly but the clicking sounds are still there. As someone else mentioned, it sometimes happens mid-back/back rest(lumbar support) area too. When i have time next to take it apart again, i might take the SEAT itself apart instead of just the railing. Pulling on the seat adjuster to change distance i am from the pedals only stops its from clicking for a little while. It comes back (i was sitting close enough to headbutt the steering wheel) after awhile of driving. I also noticed it happens more when the temperature is higher. Will get back to this once i take apart the seat itself. |
#19 |
You guys have lumbar supports?
I'm jealous
#20 | |
Hopefully you won't have to take the seat apart, however, it could be that a spring inside the seat has become detached - ![]() humfrz |
#21 | |
#22 |
Weight Weenie
Drives: 15 FR-S
#23 |
Drives: Toyota gt86 my19
nothing else is known? I have the same problem
#24 |
I swapped seat, and actual one sometimes makes a click from lumbar support too..
#25 |
#26 |
I hear the click coming from that part, yes.
#27 |
My toyota avensis, had the same problem
| WTB: frs base drivers seat | icybrzzz | Canada Classifieds | 0 | 03-17-2017 07:44 AM |
| WTB: drivers seat for FRS | Beckder | Canada Classifieds | 4 | 04-15-2016 07:51 PM |
| FRS drivers seat | Beckder | Want-To-Buy Requests | 1 | 01-05-2016 02:22 PM |
| clicking noise from drivers side rear | CARBONGT86 | CANADA | 11 | 08-23-2015 06:58 PM |
| RHD drivers seat | Basti | Want-To-Buy Requests | 0 | 09-07-2013 01:31 AM |
