| Engine Swaps Discussion of engine swaps. |
#15 | |
Yes you could manage to do it cheaper with more available engines but the OP was specific to the 2jz. You could also do the FA20 build cheaper if you just buy the parts and build it yourself instead of buying a pre built engine. Overall the built FI is going to cost far less than a swap. There are maybe 10 successfully completed swaps documented on this forum compared to the thousands of FI cars. The biggest reason for that is cost.
#16 |
Drives: LS Swapped Scion FRS = 440HP
#17 |
I would have given you $3,001 just so I don't have to clean mine this summer! So much sand. So, so, so much sand.
#18 |
Drives: Slow
That was the offer I've gotten for mine. I have less than 2,100 miles on my 2018 model year. I, too, am looking into swapping but for an LS (maybe LS3). I'm not expecting much from mine either.
#19 |
Drives: Red BRZ
I did my swap and have all functions working except for cruise for roughly 11k, and still haven't been able to sell my engine and trans for 2k obo with 83k miles. Its possible to do it on the cheaper side; cheaper side being 7-8k.
Sent from my SM-G950U using Tapatalk |
#20 | |
Drives: 13 FR-S, 90 Honda ED6, 07 TBSS
#21 |
Drives: Red BRZ
#22 |
Drives: turbo frs
Hi guys 👋
Thanks allot for your reply I build my engine with New crankshaft New cp pistons New 🦅 rods New bearings James at hri well tune the car The goal is 400whp This well reduce cost of engin swap .. Thanks 😘 again |
#23 | |
pessimistic skeptic
I think, you will waste the money and end up with a mess that will go directly to junk. Leave the car alone. You are not up for it yet. |
#24 | |
Drives: turbo frs
I think u miss understood me I have install also FI turbo kit Oil cooler Transmission well Handel 400whp with no issue More than this well coze trans slip |
| Next Car Recommendation | Prmspen | Other Vehicles & General Automotive Discussions | 21 | 10-12-2018 07:43 PM |
| Dead RB25 Swap, Alive 2jz swap | -Phil | Engine Swaps | 72 | 09-15-2018 02:35 PM |
| Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions | Dezoris | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-06-2017 10:54 PM |
| Recommendation for GTA PDR? | 1Cor10:23 | CANADA | 12 | 11-08-2014 09:08 PM |
| Non LED recommendation for DRL | boredom.is.me | Cosmetic Modification (Interior/Exterior/Lighting) | 13 | 05-11-2013 05:34 PM |
