Old 01-02-2019, 06:11 PM   #15
humfrz
Originally Posted by ph4zon View Post
After a couple months, the front rotors on my RR Racing Sport kit are looking pretty nasty where the brake pads don't touch.
I think the rotor looks just fine - however, the rest of the wheel is a mess -
humfrz
Old 01-02-2019, 06:21 PM   #16
ls1ac
ls1ac's Avatar
We drive the car quite hard and the rotors get cherry red. That is about 1300 F. The paint said 900 F intermittent.
The Following User Says Thank You to ls1ac For This Useful Post:
wparsons (01-03-2019)
Old 01-03-2019, 12:41 PM   #17
TheBRZsKnees
TheBRZsKnees's Avatar
Drives: 2014 BRZ
Originally Posted by SuperTom View Post
Do you recommend that over something like this? The car only sees occasional spirited driving, so I don't think the rotors get super hot.
https://www.amazon.com/gp/product/B0...KIKX0DER&psc=1
humfrz
You're not wrong. Seattle weather hasn't made it easy to keep her pretty and clean.
TheBRZsKnees is offline   Reply With Quote
Old 01-03-2019, 01:16 PM   #18
humfrz
Fer sure, fer sure. One year, a few years back, my father and mother, who retired in California, bought me a "California Duster" for my cars.
I reckon he didn't realize that we didn't have "dust" here in the PNW. Ya can't have "dust" when it rains twice a day -
humfrz
Old 01-03-2019, 01:41 PM   #19
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
why not get the 2000 degree paint its the same price?
SuperTom is offline   Reply With Quote
Old 01-03-2019, 02:09 PM   #20
TheBRZsKnees
Drives: 2014 BRZ
My only concern is that requirements to cure a higher-heat primer may be more stringent. That's just a guess though. Also, might there be advantages to staying consistent with the primer and paint brands?
Other than that, yeah, it seems like the Rust-Oleum one has a greater benefit.
Old 01-03-2019, 02:43 PM   #21
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
My only real concern is that re requirements to cure a higher-heat primer may be more stringent. That's just a guess though. Also, might there be advantages to staying consistent with the primer and paint brands?
Yes, I believe you have to cure it at high temperature.
Old 01-03-2019, 04:31 PM   #22
SuperTom
SuperTom's Avatar
Yeah that could be true. I would go to you nearest pepboys and read the cans. 500 degree may work if you are only cruising around
Old 01-03-2019, 05:14 PM   #23
Leonardo
Country Boy 4 Life
Leonardo's Avatar
The VHT paint said to bake the parts in the oven for an hour at 200 F.
Which is totally doable, but a PITA!
I LIKE TIRES!
TheBRZsKnees (01-03-2019)
Old 03-15-2019, 10:32 PM   #24
TheBRZsKnees
Drives: 2014 BRZ
Sorry for the late update. I ended up using Dupli-Color Engine Enamel Primer and and silver Caliper Enamel with Ceramic. The paint has held well for the last couple months. It's a big improvement over swaths of rust, but the silver doesn't look very good. I'm planning to redo it black.
Old 03-15-2019, 10:39 PM   #25
humfrz
YIKES! One of those lug nuts has a nick on it - how do you stand that?
humfrz
Old 03-15-2019, 10:58 PM   #26
Spawn_Of_Creation
Human
Drives: 2015 BRZ Black
Clear coat is not high temp. I would use brake cleaner to clean the brakes. I also would tape off areas you do not want painted. Unless you want paint in your slots....
You can get a high heat clear coat (https://www.amazon.com/Dupli-Color®-.../dp/B0082LGJ2C), but it's not necessary.
"Always listen to experts. They'll tell you what can't be done, and why. Then do it." - The Notebooks of Lazarus Long
Spawn_Of_Creation is offline   Reply With Quote
Old 03-15-2019, 11:00 PM   #27
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Thanks!
I LIKE TIRES!
Tried to prevent rust, may have made it worse... KPR10 Issues | Warranty | Recalls / TSB 36 04-24-2015 04:04 PM
Prevent or Repair Exhaust Tip Rust h8meh8ers Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 7 09-03-2014 12:51 AM
Autobody Shop/Painting Near Me ? Issue with Painting Carbon Fiber Hood? ScionFR-S Cosmetic Modification (Interior/Exterior/Lighting) 20 11-08-2013 02:51 PM
Rust? even with rust proofing? Chinadian Issues | Warranty | Recalls / TSB 8 01-26-2013 05:15 PM
