Old 12-29-2018, 01:49 PM   #15
mkodama
86 Challenge
Drives: 2017 BRZ
FFS!! What next?? Checking the car tyre pressures after having established a "benchmark" and letting the tyres go through a heat cycle but ensuring that they've cooled down for approximately 27minutes at 27c at sea level.. however, if nitrogen filled then you're fucked!
You must not be able to ignore this thread since you’ve already posted 3 times over 2 days.
mkodama is offline   Reply With Quote
Old 12-29-2018, 02:13 PM   #16
Ultramaroon
not playing cards
Ultramaroon's Avatar
It's like rubbernecking past an accident. If it's bad enough we might loop around for a second look.
Old 12-29-2018, 02:14 PM   #17
JD001
JD001's Avatar
Drives: Subaru BRZ
You're right... I am holding out for gems in amongst the dribble... Ole Humfrz hits it out of the ball park..
"just keep it between the holes".
(Does not apply when having sex).. LMAO!!!
Old 12-29-2018, 03:08 PM   #18
humfrz
OK, OK, OK - you're right!
Lets go back to the old days and use the KISS method.
Pull out the dipstick (anytime the engine is not running) and take a reading. If the oil doesn't show up on the dipstick, add a quart of oil. If the level does show up anywhere on the dipstick, you're good to go. If the level shows over the full mark, don't worry about it (especially if it's a Ford) because the engine will either burn off or leak out the excess.
There ya have it, now just drive the fucking car and don't worry about it.
Oh my, it's ma med/pain killer pill time -
humfrz
Old 12-29-2018, 03:37 PM   #19
highway7
Drives: FRS 2013
Check the dipstick first thing in the morning, make sure you are on level ground. The "Wait at least 10 minutes" is for the oil to drain back into the drain pan to give you the most accurate reading, however this is dependent on a lot of factors (Oil life, temperature, viscosity, what oil you used, some people using 5W30, etc). If you check after leaving it overnight then you know for sure all of the oil is there. I change my own oil and always drain out exactly what I put in (5.5L) and it reads exactly on the MAX dot when I check in the morning.
I swear some people around here need torque specs for the license plates
highway7 is offline   Reply With Quote
Old 12-29-2018, 03:50 PM   #20
JD001
JD001's Avatar
Drives: Subaru BRZ
Do you use a theodolite to establish your "benchmark"?
Old 12-29-2018, 03:56 PM   #21
Ultramaroon
not playing cards
About 35 inch pounds.
Old 12-29-2018, 04:19 PM   #22
humfrz
Now, hold on just a cotton picking minute. My license plate bolts have a slot for a screwdriver and a head that will accommodate a wrench or socket.
So, is your 35 inch pound torque measurement correct for either method of tightening the bolts down???
Now, jest chew on that cud for a spell while I drag my aching body into the bedroom for a looong nap.
humfrz
Old 12-29-2018, 04:23 PM   #23
JD001
JD001's Avatar
Drives: Subaru BRZ
humfrz
And, what if the license plate is offset?
Old 12-29-2018, 04:36 PM   #24
humfrz
Good point -
humfrz
Old 12-29-2018, 04:40 PM   #25
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Three ugga duggas
Old 12-29-2018, 05:08 PM   #26
highway7
Drives: FRS 2013
Three ugga duggas
3? You need at least 5 with a 1 inch drive. Get your death trap off the road.
Old 12-29-2018, 05:32 PM   #27
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Wobble extensions reduce overall torque applied - what do I do?
Old 12-29-2018, 08:27 PM   #28
soulreapersteve
Contract? /人◕ ‿‿ ◕人\
soulreapersteve's Avatar
humfrz
This is what my dad taught me when I first started driving.
I miss my first car. Wish I still have it. Too bad one of my relatives trashed it and its in car heaven now.
The Twins make me smile
OFT CAL confusion? Madara Software Tuning 5 08-04-2018 11:20 AM
Replacement Key Confusion pwest BRZ First-Gen (2012+) — General Topics 7 10-25-2016 03:08 PM
Exhuast confusion xsnapshot Engine, Exhaust, Transmission 10 06-30-2015 02:21 PM
Exhaust Confusion Strife26 Engine, Exhaust, Transmission 8 05-03-2015 07:42 PM
Alarm confusion Fugazi BRZ First-Gen (2012+) — General Topics 9 07-12-2012 12:20 AM
