Old 12-30-2018, 01:02 PM   #15
wparsons
wparsons's Avatar
Originally Posted by hachi roku [86] View Post
-2.5* would make me happy. Will be on 17x9 ET35 for track use next season.
I’ve got a pair of Whiteline camber bolts, mounted top, and can get about -1.1*, not more. What’s the right combination of bolts?
I would get the SPC bolts for the lower hole and put the stock lower bolts in the upper holes.
Another option is slotting the upper holes in the struts.
You won't have clearance for -2.5* on 9" +35 wheels without camber plates though, I maxed out around -2.4* with 17x8 +45, and you'll have 2mm less clearance.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
hachi roku [86] (01-01-2019)
Old 01-01-2019, 06:58 PM   #16
hachi roku [86]
Drives: Toyota GT86, Mazda MX-5 NB
Makes sense. So I should get about -2* on my setup. Still better than -1.1*-ish I have now, so I'll give it a try. Will report back after I try
hachi roku [86] is offline   Reply With Quote
The Following User Says Thank You to hachi roku [86] For This Useful Post:
wparsons (01-02-2019)
Old 01-01-2019, 10:27 PM   #17
H1C
Drives: 2014 FR-S MT
Ground Control is another option for plates that won't add to ride height and will increase compression stroke.
I got mine in the member classifieds here and love them: they have a serviceable radial bearing, hold settings well, and have been quiet and rattle-free. The main bearings still move smoothly and have no play, after approximately five years of use between the original owner and myself.
https://groundcontrolstore.com/colle...russ-bar-shown
http://www.ft86club.com/forums/showthread.php?t=23256
H1C is offline   Reply With Quote
The Following User Says Thank You to H1C For This Useful Post:
smg1138 (02-26-2019)
Stock brz ride height BRZ.DEX Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 01-10-2021 04:08 PM
STX Ride Height smg1138 Tracking / Autocross / HPDE / Drifting 27 03-28-2020 09:48 AM
Velox chamber plates and ride height? BRZHarley Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 09-01-2017 07:06 PM
Stock Ride Height? JimmyMac Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 03-10-2015 11:46 AM
BRZ vs 86 stock ride height Moe AFRICA 2 11-21-2013 08:35 AM
