Old 12-14-2018, 04:27 PM   #15
Gunman
Drives: 2019 Mazda Miata RF
For looks mostly, I'd go springs. I've been running Hotchkis drop springs, on OEM dampers for over 70k daily driver miles, and lots of weekend twisty mountain driving, and I have no complaints.
Gunman is offline   Reply With Quote
Old 12-14-2018, 06:03 PM   #16
jflogerzi
jflogerzi's Avatar
Originally Posted by N1rve View Post
If you plan to get aftermarket rims -- consider this, are you going to get wheels that require coilovers with the smaller spring perch? If you do -- then I would go for coilovers (Tein Flex Z / A).
Also -- consider the mileage on your existing suspension. Are you around 50-60k miles? Might as well overhaul your suspension. If you're like 10k-20k miles then I would just get springs since dampers are still good.
I will echo this. Another option if you can find it is a used cheap set of 2017+ OEM damper(not PP ones) and add your springs. I went this route with Yellow Springs, camber bolts and rear LCAs.
2013 Series 10 FRS #553
Old 12-14-2018, 06:21 PM   #17
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
I'm not going to argue one vs the other, but I just want to point out that my KW V3 coilovers are quite comfortable, and pretty close to stock ride comfort. It's one of the reason I chose them as I live in Chicago, where the roads are horrid.
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
Old 12-15-2018, 12:10 AM   #18
Grey86
Grey86's Avatar
Drives: Tornato grey 86
ill get aftermarket rims but thats planned on years down the road im slowly trying to build this how i want it without breaking the bank at once. ive already got a body kit on the car ive got a exhaust coming in the next month and im about to purchase spacers for the stock wheels to have that flush look.
The car only has 7000km (4300 miles i think) and ive owned it for a year now (its a small town nothing over 5 minutes)
Grey86 is offline   Reply With Quote
Old 12-15-2018, 03:54 PM   #19
Impureclient
Drives: 2015 FR-S
Why aren't leaf springs ever an option?
Impureclient is offline   Reply With Quote
Old 12-15-2018, 06:01 PM   #20
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
I like these better.
Old 12-15-2018, 06:09 PM   #21
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
My view is also that coilovers can add a lot of complexity for suspension tuning. With springs generally you're just adjusting camber. Coilovers have a lot more fine tuning that CAN be done (especially those with different top hats) and this also leaves a lot more room for error. I'll take a spring that I can't mess up, rather than coilovers for my DD needs.
Old 12-15-2018, 06:19 PM   #22
Impureclient
Drives: 2015 FR-S
That looks like it might be uncomfortable to work with, this one looks more pliable and give a more compliant ride:
Old 12-16-2018, 01:01 PM   #23
pinoy_dorifto
Tuloy po kayo!
Drives: 2019 Toyota 86 TRD SE
Swift Spec-R on mine, 1" drop I daily and I track, also have camber plates on top for more camber. Great combo with my MY17 shocks and TRD USA sway bars.
I.G. @mytoy86
pinoy_dorifto is offline   Reply With Quote
Old 12-17-2018, 11:44 AM   #24
Gunman
It's an option, but installation is a bit more complex. I'd go transverse mounted, and it would also lower Cg.
Old 12-17-2018, 12:22 PM   #25
firekat
Drives: 2018 Subaru BRZ tS
Transverse Leaf Spring? Been there, done that (Triumph Spitfire/GT-6).
Who votes for Torsion Bars? Did that too - Porsche 924 Turbo.
firekat is offline   Reply With Quote
Old 12-17-2018, 12:56 PM   #26
TMF
TMF's Avatar
Drives: '14 FRS TT5
TRD springs + Koni yellows (direct replacements). Looks good and rides great - the Koni's are adjustable, so you can go from as soft as stock up to pretty darn stiff. For reference, the wheels are 17x9, +35 with 225's (these tires run wide) and had no fitment issues.
Unless you really need the performance or ride height adjustability of coilovers (and want to increase your budget), lowering springs are a great choice. There are plenty of great spring options for this platform, and pairing them with Koni's will allow you to preserve your ride comfort.
Follow my NASA TT5 build here: JHill Motorsports
TMF is offline   Reply With Quote
Old 12-17-2018, 07:45 PM   #27
Gunman
Corvette still uses the transverse leaf.
Old 12-17-2018, 10:39 PM   #28
firekat
Didn't know that.
1" drop, coils or springs? HachiRo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 06-18-2016 05:34 PM
Swift Springs and BC Coils-Great Deals!!! FBPARTS Brakes, Suspension, Chassis 47 07-02-2015 01:02 PM
springs or coils? whip Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 04-04-2015 10:42 AM
Struts / Springs VS Coils eddieEndo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 02-23-2014 09:59 AM
J2 Motorsports- Suspension l Springs l coils l Strutbars- -BEST PRICES*FREE SHIPPING J2 Motorsports Brakes, Suspension, Chassis 9 11-01-2012 10:27 PM
