Old 03-25-2019, 01:30 PM   #15
Flash02
Drives: 2017 Subaru BRZ Limited
I called tech support, they think it’s because I’m using the BNC connections vs splicing into the new HU wire harness. I assumed that since my BRZ has a factory Amp I would use the BNC connections.
Flash02 is offline   Reply With Quote
Old 03-25-2019, 08:43 PM   #16
Flash02
2017+ BRZ and Maestro RR
Okay so my issue was using the BNC connections in the iDatalink harness, apparently those connections do not provide enough power to the amp. I cut the BNC connections off and wired direct to the Pioneer main harness. All is good. Before it sounded like pillows were covering the speakers.
Old 03-31-2019, 05:05 AM   #17
UT_BRZ
Drives: 17 Limited BRZ
Originally Posted by COBlue View Post
iDatalink has updated the firmware to 1.4 and TPMS now works with the SU2 harness. Interestingly they are pulling the from the CAN bus so might be possible to use the CAN plug behind the radio on the right instead of OBD? iDatalink wouldn't confirm this.
I have mine wired to the CAN plug behind the radio/glove box and all of the gauges as well as the TPMS works. I needed the OBD plug available for the ECUtek since I'm boosted. I haven't ever been able to get the track package to work on my head unit.
UT_BRZ is offline   Reply With Quote
Old 04-01-2019, 06:58 PM   #18
COBlue
COBlue's Avatar
Drives: 2017 Subaru BRZ Limited PP
I'm getting OBD connection issues now so wondering if a wire from the CAN came loose...
I believe my track pack started working when I switched from the TO1 to the SU2 harness. (And be sure you double tap the brake to initiate the track pack recording.)
COBlue is offline   Reply With Quote
Old 05-20-2019, 12:10 AM   #19
Chuckable
Drives: 2017 Toyota 86
Any updates on this thread? Interested in hearing is issues have been resolved yet.
Chuckable is offline   Reply With Quote
Old 05-20-2019, 12:23 AM   #20
COBlue
COBlue's Avatar
I soldered (vs. the plug I stole from my kid's Arduino) the connecting wires to the CAN behind the radio and OBD data has been fine. Track pack has always worked since SU2 and updated firmware.
Old 05-20-2019, 03:32 AM   #21
Drifter X
Drifter X's Avatar
Drives: 2019 Toyota 86 TRD SE
Hey there. This might be a dumb question but was your backup camera originally displaying the rear view mirror? I literally have the same setup as you but can't get the backup camera to display on the HU. Mines still displays in the mirror. I also had mines wired up by Crutchfield.
Drifter X is offline   Reply With Quote
Old 05-20-2019, 07:23 PM   #22
COBlue
COBlue's Avatar
Howzit from a Kaneohe boy...
Nope, Maestro yellow RCA video plug goes into the back of the HU and BU camera displays on the HU. Seems like that would take some work and wire crossing to get it on the mirror!
Old 05-20-2019, 07:38 PM   #23
Drifter X
Drifter X's Avatar
Hooo howzit brah! Just confirming did your BU camera display in the mirror before? Or was it displaying in the stock HU? I'm trying to figure out where my wiring went wrong. You'd think Crutchfield would be more helpful since they wired it up for me but they don't know why either. I've been told it's better if I just by another BU camera and wire it up to the HU.
Old 05-20-2019, 08:07 PM   #24
COBlue
COBlue's Avatar
Never displayed in the rearview (didn't even know it could - did that in a different car but after market mirror), always displayed in stock HU.
I briefly looked at swapping out the BU camera when I thought I'd lose my guidelines with new HU...looked like a pain in the twins. (Did it previously in two other cars that didn't have cameras at all.) Don't see how that could be easier - especially since you'd have to run a new wire through the car if the current is wired up odd.
Pretty straightforward - camera wire goes to Maestro goes to HU...
The Following User Says Thank You to COBlue For This Useful Post:
Drifter X (05-20-2019)
Old 05-20-2019, 08:09 PM   #25
Drifter X
Drifter X's Avatar
Right on thanks for the info!
Old 05-28-2019, 02:21 PM   #26
Ginotjr
Drives: 2019 Toyota 86 GT
Hello, did you find a solution for this? I'm planning on doing the same with Crutchfield. Thanks!
Ginotjr is offline   Reply With Quote
Old 05-28-2019, 02:26 PM   #27
Drifter X
Drifter X's Avatar
No unfortunately... The last time I spoke to tech support was in January and the choices then were to splice the signal wires at the mirror with a video RCA or buy a new camera and wire like you would normally. I watched a video on YouTube about the the whole splicing route and yeah I'm not confident in doing that. So I deal with the backup camera displaying in the mirror. Lmk if you find another way!
Old 06-23-2019, 10:51 PM   #28
haohmaru
Drives: Red 2024 GR86 Trueno
I have a Pioneer Avh-2550 and the steering wheel controls stop working if I use any of the physical buttons on the head unit. Turning on and off the car gets them working again. Is this happening to anyone else?
haohmaru is offline   Reply With Quote
Installing Pioneer HU and Maestro RR NCtoBRZ Electronics | Audio | NAV | Infotainment 56 05-20-2019 09:16 AM
AVIC-8201NEX without iDatalink Maestro? sgh Electronics | Audio | NAV | Infotainment 7 04-19-2018 02:42 PM
CSCS Mid Summer DRIFT 2017 - Round 3 - SUN July 23 2017 @ TMP CAYUGA SB LAYOUT DTrouble CANADA 0 07-19-2017 09:42 PM
2017 CHRYSLER PACIFICA MINIVAN VS 2017 TOYOTA 86 WHO WINS IN A DRAG RACE??? Extreme Dimensions Off-Topic Lounge [WARNING: NO POLITICS] 6 06-08-2017 09:59 AM
Maestro idatalink test dummy tofurun Electronics | Audio | NAV | Infotainment 30 10-18-2016 02:01 PM
