Old 11-16-2018, 06:57 PM   #15
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
91? E85?
Old 11-16-2018, 07:07 PM   #16
Irace86.2.0
What GenRuleAThumb said, 10psi at redline? or are you hitting peak boost earlier and the wastegate is keeping boost flat from there? Too much low end torque maybe
Old 11-16-2018, 07:41 PM   #17
GrabTheWheel
Drives: 16' BRZ
Originally Posted by whataboutbob View Post
If you look at most of the stock motor failures with boost it is the connecting rods that fail.
Next two most common causes of failure are spun rod bearings (from low oil and/or oil starvation), and valve train failures (from over revving the motor and/or manufacturing defects in the rocker arms).
Depending on your budget and goals, I'd say at a minimum you'd want to rebuild with forged rods and pistons. A damper pulley is also a good idea in my opinion.
I 2nd the damper pulley. If you're interested I have one for sale.
http://www.ft86club.com/forums/showthread.php?t=130989
GrabTheWheel is offline   Reply With Quote
The Following User Says Thank You to GrabTheWheel For This Useful Post:
whataboutbob (11-16-2018)
Old 11-18-2018, 11:06 AM   #18
fer3d
Drives: Toyota 86 FT
Full boost around 4600rpm. Flat from there
Peak torque 328Nm at 5200rpm
fer3d is offline   Reply With Quote
Old 11-18-2018, 11:11 AM   #19
fer3d
91? E85?
91
Old 11-18-2018, 01:41 PM   #20
Irace86.2.0
91
It seems like a decent amount of power for 91 and definitely a lot of torque at low rpms, so even with a great tune it was a matter of time.
Is my engine blown? dallenj Engine, Exhaust, Transmission 39 01-30-2017 05:18 PM
Blown engine due to 0W-20? Benschneider06 Engine, Exhaust, Transmission 45 07-23-2015 03:33 AM
CEL - Engine Blown!!!!!!! rapidcars Issues | Warranty | Recalls / TSB 65 12-10-2014 10:32 PM
Any body have a p&l turbo kit for sale or full blown turbo Anthony7515 Want-To-Buy Requests 2 06-06-2014 06:43 PM
fs feeler full blown turbo kit minus turbo kingkai23 Engine, Exhaust, Bolt-Ons 10 03-11-2014 03:59 PM
