Old 11-06-2018, 03:17 PM   #15
nico_rsx
Drives: BRZ 2017 Pure Red, MT
The 2017 MY are supposedly harder to close because they made the gas shocks harder to better support the wieght of the aluminium wing. But I think they made them a bit too hard.
nico_rsx is offline   Reply With Quote
Old 11-06-2018, 03:45 PM   #16
cjd
cjd's Avatar
Drives: 2017 BRZ
My '17 takes a lot more effort than my '14 did. Stupid amounts more. Not to get it to shut, but to actually latch successfully.
Originally Posted by bmxr View Post
Pressing down from the middle of the trunk helps a little.
If you have the wing, doing this will cause it to dent the trunk in the middle.
Old 11-06-2018, 04:25 PM   #17
wolffbite
Just the tip
wolffbite's Avatar
Drives: 2017 DGM BRZ
Learn something new every time I flip through the ole manual...
I'm guessing the middle of my trunk is pretty dented by now
wolffbite is offline   Reply With Quote
Old 11-06-2018, 04:27 PM   #18
cjd
cjd's Avatar
Drives: 2017 BRZ
Yeah, I noticed mine is dented. I'm not the only one that has closed the trunk, so who knows when it happened. Stupid design.
Old 11-06-2018, 05:15 PM   #19
bmxr
bmxr's Avatar
Drives: 2017 BRZ PP WR Blue
I will check and see if the trunk is dented under the spoiler bumper. If I push down from either side instead of from the middle, it won't latch. I took the latch apart once but it did not seem like there was any adjustability unless I start modifying things...
bmxr is offline   Reply With Quote
Old 11-06-2018, 06:42 PM   #20
dhuang
Cannonball Record Guy
dhuang's Avatar
Drives: Series.Yellow, 4C, Fit
Originally Posted by dhuang View Post
Inspect the striker plate as well -- the rubber bumper on mine split apart ~15k miles, and the latch was hitting the metal. The dealership had to replace the striker plate and latch to the tune of $200 (under warranty) just because the little rubber piece broke.
I just went out to my car... and the rubber piece is starting to split yet again.
2017 Series.Yellow
2013 Whiteout
VINwiki - Changing Automotive History
dhuang is offline   Reply With Quote
Old 11-06-2018, 06:50 PM   #21
Leonardo
Country Boy 4 Life
Leonardo's Avatar
With junk in my trunk that didn't allow it to close nicely, I slammed it shut and cracked my tail light. Stupid. I would suggest not doing this...
I LIKE TIRES!
Old 11-06-2018, 07:35 PM   #22
humfrz
well, don't try to store all of your old OEM suspension parts in the trunk.
humfrz
Leonardo (11-06-2018)
Old 11-06-2018, 08:19 PM   #23
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Harder struts are only on cars with stock wings.
I should also clarify, I said mine was hard relative to the doors, but it's still not terribly hard, from wide open I just put one finger in the cowboy hat and shut it in one motion. The only times I've had it fail to latch is when I tried to give it a swing and let it go, the struts just completely slow it down.
(Edited for autocomplete shenanigans)
Old 11-06-2018, 09:15 PM   #24
nico_rsx
Maybe, but OP has a BRZ, and all 17' BRZ have the OEM wing.
Old 11-06-2018, 09:23 PM   #25
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
My '17 BRZ did the same thing when I first got it. Never had the issue with my '13 FRS but I did buy that one used.
It seems like eventually things "break in" with the latch mechanism and now the trunk lid shuts nice and smooth.
I seriously thought my trunk was broken or defective it was so hard to shut when I first bought it.
justinco is offline   Reply With Quote
Old 11-07-2018, 03:04 AM   #26
spike021
spike021's Avatar
Interesting. Mine still has the problem, but I know the 'right' way to close it and avoid the issue most of the time (still happens occasionally).
But yeah, first night I had the car I left the trunk 'open' overnight because I thought I closed it, only to find out in the morning it hadn't latched.
Instagram: @spike.grc
spike021 is offline   Reply With Quote
Old 11-07-2018, 11:48 PM   #27
humfrz
26 posts commenting on shutting the trunk lid on a car.
humfrz
spike021 (11-08-2018)
Old 12-22-2018, 10:42 AM   #28
wild03
Drives: Silver 2017 Limited with PP
Thanks for all the replies, I did a quick inspection of the latch and I think that those blaming the striker plate are on to something.
If you look at the rubber bumper notice how the arm where it seats pivots up higher than one would expect and the rubber is contacted at an angle, almost at a 45 degree. I would think that moving the arm down a bit, maybe by putting a little rubber on the arm stop to prevent it from going up as high.
in any case the striking of the rubber is not an a ideal angle, this explains the rubber not lasting, and the effort required.
I will take a closer look soon by removing the plastic.
wild03 is offline   Reply With Quote
2017 Toyota 86 Trunk Lid GrayFox_27 Want-To-Buy Requests 0 06-23-2018 01:48 PM
Trunk needs a bit of force to close..... Hachiroku14 Issues | Warranty | Recalls / TSB 30 06-19-2018 06:09 PM
TRADE: 2017 BRZ trunk and wing for wingless trunk?? Moto CANADA 0 05-19-2018 04:21 PM
WTT 2016 limited trunk for 2017 trunk Ignore Your Doctor Southeast 0 08-27-2016 10:32 AM
