#15 | |
Drives: Q5 + BRZ + M796
#16 |
First priority is making sure you have wheels and tires fit, and choosing the right tire. 18x9.5 wheels and 265s are very large and not ideal for most people. Yes, they can work, but life will be a little easier even with just 9 inch wide wheels and 245s or 255s.
To help choose the right tire....how much track experience do you have? Is your car NA or do you plan to turbo? - Andrew |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | Leonardo (10-25-2018) |
#17 | ||
#19 | |
That One Guy
Drives: White 2017 BRZ
well, the coils are built around the wheel in this instance. Due to the PP, i have limited options on wheels that will fit on the car and look good (...imo, naturally). Since i am going with titan 7's, I am stuck with a 9.5" width. Now, the tire size is more a point of contention, and after reviewing other peoples builds and statements, i'll just stick with 245 based on others comments and further review. The car will not be turbo'd, but kept NA. Track experience is negligible. I go every so often with friends to beat previous times, but it isnt a commitment. I just want to ensure i have a setup that will perform well under harsher conditions and spirited driving including the occasional track run. Safety and long-term durability are the takeaway points that are desired as this car will remain the DD, and road-trip car.
"I am not bound to win, but I am bound to be true."
#20 |
#21 | |
Considering he mentioned the KW V3, which are half that budget, I'm assuming maxing out his budget isn't his ideal choice. I'm of the mind, like others, that he would be better off spending some of that $4k on LCA or other supporting suspension components than burning it all on a set of coilovers, or worse, going hundreds over budget unnecessarily.
| The Following 2 Users Say Thank You to Irace86.2.0 For This Useful Post: | Leonardo (10-26-2018), strat61caster (10-26-2018) |
#22 |
+1 tein flex or something single adjustable + lca good alignment and good coaches, have fun. Kw v3 can teach you something too I think if you want to spend a bit more, dive on in make mistakes, learn, shred some tires.
#23 | |
#24 |
Drives: 2019 Toyota 86 Neptune
@Daedex
This is an interesting topic and I am sort of in the same shoes as you. I think my car rides fine stock but I want some wheels that won't fit and I don't want to make it pokey with spacers. Suspension is one area in which it seems like the usual rule of higher $ means better doesn't necessarily apply. It looks like to me there's a cliff where suspension under a certain price point has quality compromises, but once you're past that point, you're starting to trade off decisions in how you want the suspension to perform. I too have a >$4K budget for suspension but in my research it looks like the higher the $, the more track-oriented the suspension becomes, which I am finding most likely means compromises for daily driving. I think the idea behind adjustable suspension is that you can personalize it to you, but there are only so many toggles you can have on a suspension setup, those most often mentioned being rebound and compression damping. Then there will be some other aspects that are less easy to adjust, like the physical qualities of the spring installed like length and spring rate. All of these things need to work together to provide you a good driving experience. The only thing I've figured out so far, is that it's important to pick a shop that is willing to help you figure out how you want to change your ride from stock, and to understand to what lengths will they go to help you. i.e, what if you buy something, and it sucks (to you) no matter how you tweak it. Are you SOL? Can you exchange for something else without too much hassle? I think that with a suspension purchase, you're effectively rolling the dice until you have it mounted on your car, with the wheels and tires you will use, and given some time to tweak settings. Sometimes you'll get lucky and you'll be happy out of the box with recommended settings, sometimes it will be hard to describe what you don't like about it, relative to what you previously had as suspension. This is why you want to work with experts that know what they're doing and want you to be happy, and will be willing to spend HOURS with helping you, versus those that are just selling stuff. Fortunately for us, RCE and CSG seem like they're invested in helping 86/BRZ/FRS drivers, but we as customers too have to do our part to figure out how to qualitatively and quantitatively describe what we want. Both have been mostly responsive to me over email but unfortunately I've yet to buy anything. I'm personally leaning towards trying the "new" Ohlins R&T with softer spring rates. This is because I have a 2019 86. I don't know if all suspension has been updated to match the 2017+ chassis updates but it seems like the Ohlins is most likely. I also like that it's made of aluminum and that I believe it's the only thing on the market with "DFV" which is patent protected which makes it a bit more unique. I don't know if it's any better than any other valving. I don't believe they licensed the technology to anyone. I have no idea if I'll like it or what it will be like vs stock. Sure would be nice if there was a way for shops do suspension rentals or something like that.. lol. obviously easier said than done but there probably is a business plan and price point that could make it worth it. |
#25 |
We had a huge meet like 10 years ago with a lot of volunteers giving rides in their cars. We had almost every suspension set up available covered at the time.
- Andrew |
#26 |
Drives: 2014 GT86
antmit: expert suspension shop workers often also have waste experience of how to ask/find out in layman's terms what change car owner actually want/need (which in reality might be very different of what it seems to customer that he needs/wants
). Gathering nfo from non tech-savvy customer also is a skill, that needs to be developed
| The Following User Says Thank You to churchx For This Useful Post: | Racecomp Engineering (12-14-2018) |
| Meet "Storm" Errol's 86 Progress/Build Thread | RainEG | Member's Car Journals | 15 | 06-30-2020 02:12 AM |
| Vicious LED "BABYLFA" Asphalt FR-S Build Thread! | Vicious LED | Member's Car Journals | 111 | 01-24-2014 02:20 AM |
| Is there a collective "stock parts weight" thread? | Bullnettles | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 05-28-2013 01:46 PM |
| The "if you wanna kiss the backside of white musicians make a thread about it" Thread | aliphian | Off-Topic Lounge [WARNING: NO POLITICS] | 8 | 12-19-2011 07:59 PM |
