#15 |
Drives: 2014 GT86
Leonardo: if you are from those that lowering >1", worth install also some diff riser in rear, for CV joints to not fail too soon.
| The Following User Says Thank You to churchx For This Useful Post: | Leonardo (10-23-2018) |
#16 |
Country Boy 4 Life
Thank you for the reply. What brand of "diff riser" do you suggest?
I LIKE TIRES! |
#17 |
Country Boy 4 Life
IMO, you can see the finish difference (hopefully not quality) between the new bumpsteer kit parts and my tire rods.
Supporting mods... Once the front sway bar arrives; it's going to be install time! ![]()
I LIKE TIRES! |
#18 | |
Drives: 2014 GT86
From googled up, riser from PSM for example. Try googling yourself, by adding "site:ft86club.com" to keywords of diff riser |
#19 | |
Country Boy 4 Life
I've looked at their stuff, almost ordered their LCA. I'll check those parts out, thank you! And I don't plan on going much lower, the FA thread has one Vendor's suggestion at 1.1" lower. Mostly, I've been daydreaming about parts for 6 years. So, when I was finally adding parts to my cart, I thew 'em in!
I LIKE TIRES! |
#20 | |
Awesome, those definitely look like new parts.
| The Following User Says Thank You to wparsons For This Useful Post: | Leonardo (10-23-2018) |
#21 |
Drives: 2013 Raven FR-S
Finally ordered my kit last week. I'm lowered 1.5" on coils and have put over 90k miles on my original ball joints. Since Whiteline brought this kit back I figured I might as well put them in. It'll be good peace of mind getting the geometry back to ideal position.
| The Following 3 Users Say Thank You to smg1138 For This Useful Post: |
#22 |
Drives: '18 86 (Asphalt)
How much do the bumpsteer kits actually raise the roll center?
#23 |
#24 | |
I would imagine they raise it quite a bit more than that... they might be 20mm extended though.
#25 |
Drives: Legacy GT
I don't think the height difference between the stock and whiteline parts is that much. 5-8mm maybe?
As far as how much that changes roll center height I don't know if whiteline has published that data (or even bothered to model it in the first place). I took a look at the suspension geometry coordinates sheet in the suspension model thread and would only have plot like 3 of those points but it's not even close to right. Last edited by jamal; 02-14-2019 at 04:01 PM. |
#26 |
Drives: 2015 Subaru BRZ
Anyone get a set from Whiteline lately? I ordered mine from them back in March but have yet to hear back.
| FS: Whiteline Camber kits unused Front and back | Lido | Brakes, Suspension, Chassis | 1 | 03-23-2018 01:44 PM |
| FS: SPL Bumpsteer Adjustable front Tie Rod Ends | corry29 | Brakes, Suspension, Chassis | 2 | 05-26-2016 12:30 AM |
| Going Back to Stock: Raceseng, RCE, SPL, TiC, Whiteline, and Super Pro | Stevo22 | Brakes, Suspension, Chassis | 8 | 03-18-2016 07:34 PM |
| Whiteline Rear Lower Control Arms KTA139 Back in Stock | Turn in Concepts | Brakes, Suspension, Chassis | 0 | 01-23-2014 03:01 PM |
| IN STOCK!!! Whiteline FR-S/BRZ Positive Traction and Shift Kits! | 10k Redline | Brakes, Suspension, Chassis | 6 | 10-16-2012 06:32 PM |
