Old 09-15-2018, 11:08 AM   #15
StraightOuttaCanadaEh
Wes
Originally Posted by raz.sofer View Post
Hi! Thank you so much for your help!
About the clicking from the rear axle, do you know anything about it or is it not as popular as I thought?
No problem, happy to help.
The clicking I'm unfamiliar with, but maybe it's a bad bushing? If it's cracked, then it'll sort of flex and pop, making that clicking noise. I would take it to a dealer and see if they can check them out underneath.
Instagram: @gt86ws
Old 09-15-2018, 01:59 PM   #16
raz.sofer
raz.sofer's Avatar
Drives: Subaru BRZ 2015
[ame]https://m.youtube.com/watch?v=fqr4vA_WX88[/ame]
This is the sound, exacly the same. People say to check the nut and I will, and it’s probably the problem. but I don’t if it can cause any vibration
raz.sofer is offline   Reply With Quote
Old 09-15-2018, 02:40 PM   #17
humfrz
Thank you very much!
I'll make sure.
Is it possible that that is what causing the vibration?
It's possible -
humfrz
Old 09-16-2018, 11:50 AM   #18
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
1. The shifter rattles above 4k rpms. I think it's worth mentioning that they have replaced the clutch at the dealership about 7000 kilometers ago.
Mine makes a wierd rattle noise too. Very low, but only at idle. Not an uncommon complaint don't sweat it.
2. (This started today after pushing the car a bit) When I turn the AC on, I get a weird whistle inside the cabin, and it stops after putting the AC on full blast, and then turning it down, but if I restart the car, it happens again.
Check the cabin air filter.
3. The car feels bumpy at 75-120kph cruise, every 3-5-7 seconds I get a very small single bump feeling, this happens on all roads so it's (probably, or the roads here are just so bad). There are no weird noises, just this small bump, like going on a road reflector, but a very very small one.
Yeah you need to isolate whether it's the roads or the car. Sounds more like a road issue than car though. I guess you could check the alignment and the rear diff and see if it is binding but I can't imagine what else it could be.
4. I searched a bit and understood that the weird "chirping cricket like" noise in idle is fine, is it really ok or should I get it the the dealer to fix it?
Yup, the crickets are normal. There's no way to get it fixed it's not a bug (pardon the pun!) it's a FEATURE!
The Following User Says Thank You to guybo For This Useful Post:
raz.sofer (09-21-2018)
Old 09-20-2018, 08:02 PM   #19
raz.sofer
raz.sofer's Avatar
Thank you for the answer!
Can you check out my other comments about the clicking noise and see if you are familiar with it?
And I need to change my cabin filter anyways in like 2k kilometers so I will check it then. The problem is now gone tho
Old 09-20-2018, 10:25 PM   #20
Ultramaroon
not playing cards
Ultramaroon's Avatar
The sound in the video clip is a loose axle nut. It makes a very distinct glassy click. Nothing else sounds like it.
Alarm system questions/issues spdmn Electronics | Audio | NAV | Infotainment 3 06-18-2015 12:17 PM
Week-End Pics ? Did you get any sweet shots of your 86 this week-end ? BC-Boy BRZ Photos, Videos, Wallpapers, Gallery Forum 36 05-28-2014 01:14 AM
Wax Sealant Pad Questions / Care Questions l0aded Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 03-25-2014 11:19 AM
FR-S/BRZ Week – Exciting Week For Owners 86_Insider Scion FR-S / Toyota 86 GT86 General Forum 2 08-09-2013 06:38 PM
MY GF's FRS confirmed for last week of May or first week of June clayrush Scion FR-S / Toyota 86 GT86 General Forum 45 04-19-2012 04:45 PM
