Old 08-15-2018, 09:56 PM   #15
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by Code Monkey View Post
Looks like they are +45.
Don't think the TC105 comes in any other offset but +35 at 17X9.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
Code Monkey (08-16-2018)
Old 08-15-2018, 10:56 PM   #16
spike021
spike021's Avatar
That top strut bolt is a camber bolt, I bet it has more then that -.5 that is says. With my 245's on 17X9 +38 57dr's they would almost touch with camber bolts.
Try to loosen the strut bolts and turn that upper one and see if it rocks the knuckle out.
What's your front camber set at currently with the camber bolts?
Instagram: @spike.grc
spike021 is offline   Reply With Quote
Old 08-16-2018, 12:46 AM   #17
Nurnburger
Drives: World Rally Blue
The wheels say the offset is 35 on them, so I'm pretty sure.
Nurnburger is offline   Reply With Quote
The Following User Says Thank You to Nurnburger For This Useful Post:
Old 08-16-2018, 10:27 AM   #18
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I took them out and gave them away. I am on coils with adjustable tophats now.
Old 08-16-2018, 12:29 PM   #19
Turbo
Drives: FR-S Turbo
That's what I'm thinking.
Pull one off and check the markings on the wheel itself. If it says +35, I would be tempted to grab a carpenter's level and measure them to verify.
Did you buy them brand new? If used, it is possible they were shaved down by the prior owner - some ppl do re-machine wheels.
Turbo is offline   Reply With Quote
The Following User Says Thank You to Turbo For This Useful Post:
Old 08-16-2018, 02:52 PM   #20
Turbo
Drives: FR-S Turbo
I just can't understand the probs you are having -again- I had 255/40R17 RS4's on a 17x9 +35 rim without any rubbing at all with a 100% stock suspension. It was close - maybe 2-3mm of room when at 27/28 psi and cold (which gave me 34/36psi hot on track) but I didn't rub.
That's 10mm more rubber than you have, so something isn't adding up.
Old 08-16-2018, 10:50 PM   #21
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Camber bolts rock the knuckle in decreasing the amount of clearance.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
strat61caster (08-17-2018), wparsons (08-17-2018)
Old 08-17-2018, 12:17 AM   #22
Turbo
Drives: FR-S Turbo
Originally Posted by gtpvette View Post
GTM still under construction
Nice to meet a fellow FFR'r here. I'm building an FFR roadster!
Old 08-17-2018, 04:42 AM   #23
Bach415
Bach415's Avatar
Drives: Whiteout FRS
^this. If you get a camber plate instead, it will move the whole strut inwards instead of the knuckle itself. The knuckle will stay in the same place. I'm pretty sure if you make the camber bolts positive, you'll gain clearance at expense of not having negative camber and looking weird.
Bach415 is offline   Reply With Quote
Old 08-17-2018, 03:13 PM   #24
mrg666
pessimistic skeptic
mrg666's Avatar
I have 17x8 +40 wheels with 245/40 tires. They have no rubbing with zero camber. But the clearance is about 10mm.
You have (25.4/2 - 5) 7.7 mm less clearance than my setup plus negative camber. If you reset to zero camber you might be able to clear without hardware change but it will still be very close.
Old 08-18-2018, 10:50 PM   #25
wparsons
wparsons's Avatar
I had 17x8 +45's with 225/45/17's and -2.2* of camber added at the knuckle with no rubbing. 17x9 +35 with 245's should only be about 2mm closer to the spring seat.
flickr
Old 08-19-2018, 11:17 AM   #26
gtpvette
Drives: 2015 FRS - FFR GTM
[QUOTE=Turbo;3122488]Nice to meet a fellow FFR'r here. I'm building an FFR roadster![/QU
It's been on the back burner for a while,,, doing a swap on the FRS.
2015 FR-S - One Day I'll Finish The Swap
gtpvette is offline   Reply With Quote
Old 08-30-2018, 02:44 AM   #27
Nurnburger
I finally got my car aligned today, which helped shed some light on the issues. It turns out that I had -2.5 deg camber in the front! That would definitely cause it to be much closer to the strut.
I had put 3mm spacers to get it to clear on the way to the shop, but I'm thinking I'll take those out now that I have a lot more clearance.
On a side note, it was mentioned to me by the shop that I shouldn't use OEM lug nuts with aftermarket wheels. Apparently "normal OEM" nuts are rounded, whereas aftermarket wheels have conical seats. My understanding is that the BRZ stock lug nuts are conical, so I should be good, but wanted to make sure.
NoHaveMSG (08-30-2018)
Old 08-30-2018, 04:32 AM   #28
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
The factory FRS/BRZ lug nuts are fine. They come with a 60 degree taper.
Not all factory lug nuts are tapered like the FRS/BRZ lugs, which is why the shop mentioned it.
It still might be worth getting aftermarket lug nuts since the OE lug nuts don't have a seat/ledge on which a socket can rest. Basically, you'll be resting the socket right on the wheel risk rubbing them if you're not careful.
EndlessAzure is offline   Reply With Quote
WTB: 17x9 wheels and tires, +42-46 offset luchadorjose Want-To-Buy Requests 2 05-02-2017 04:39 PM
17x9 TR Motorsports wheels with conti tires APEXIT53 Brakes, Suspension, Chassis 3 03-27-2017 12:17 PM
Looking for 17x9 Autocross Track wheels and tires paintdude258 Want-To-Buy Requests 2 03-17-2016 08:30 PM
Any rubbing issues with 17x9.5 +40 wheels and 255/40/17 tires? Eazy-V Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 11-02-2014 10:42 PM
