Old 08-16-2018, 04:03 PM   #15
Diegov
Drives: 12 328i f30 FBO, 135i n54 FBO, PI,
Originally Posted by FRSBRZGT86FAN View Post
Get him/her to find a 2015....
A new car lol or a 2015 hpfp? Honestly I kind of want a frs/brz/86 my 135 and 328 are on e85 and holy shit I waste more money on gas .-.
Diegov is offline   Reply With Quote
Old 08-16-2018, 04:31 PM   #16
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
sounds like somthing else other then crickets in the back ground, belt/clutch throwout bearing. Go listen by the ground behind the passenger side wheel & see if you can hear it louder and differently.
But it could just be in my mind.... Try to put 2 full tank of chevron in or simply gas with less additives so crickets can die down & it will be easier to tell.
Old 08-16-2018, 05:06 PM   #17
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
2015 or higher FRS/BRZ/86 means you avoid a lot of the little niggling issues that were present in the earlier ones
Old 08-16-2018, 05:54 PM   #18
Ultramaroon
not playing cards
Ultramaroon's Avatar
The tensioner doesn't shake like crazy you could barely tell if it shakes honestly and at first thats what I though that the belt was to long but its not unfortunately.
Pull the belt and fire it up for a couple secs. Does it squeak?
If yes, then I'll guess TOB. If no, it will most likely be some accessory or pulley. Bearings should make zero noise and have no play orthogonal to the axis of rotation. There can be a little bit of fudge factor in the idler/tensioner pulleys but they should still spin quietly.
Diegov (08-20-2018)
Old 08-16-2018, 09:07 PM   #19
Diegov
Gotcha will tell her to do it. Thanks for the help bro.
Old 08-16-2018, 09:09 PM   #20
Diegov
Talking
I did that last time and it didn't squeak so im pretty much narrowing it down to a pulley ill tell her to pull the belt and see if anything changes. Thanks bro for the help.
The Following 2 Users Say Thank You to Diegov For This Useful Post:
stevesnj (08-16-2018), Ultramaroon (08-16-2018)
Old 08-16-2018, 11:43 PM   #21
DrButtDrugs
yerp
Drives: 2015 WRX
You don't need to pull the belt just squirt some water on it. If it stops then comes back it's 100% the belt.
DrButtDrugs is offline   Reply With Quote
The Following 2 Users Say Thank You to DrButtDrugs For This Useful Post:
Diegov (08-20-2018), Ultramaroon (08-16-2018)
Old 08-16-2018, 11:56 PM   #22
Ultramaroon
not playing cards
I'm adding this to my bag of legit tricks.
Diegov (08-20-2018)
Old 08-17-2018, 06:26 AM   #23
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Replaced the belt already still does it lol
There are things other than the belt that can cause belt chirp like that.
Do this simple test: Take a can of silicon lube (the kind you spray on window and door seals) and as the engine is running, spray just a bit on the grooved side of the belt. If the chirping stops for a moment, you've found the source of the problem.
It may be belt tension related, but IF it's coming from the belt, I'd put my dime on a worn alternator pulley. Take the belt off, use black paint to paint the alternator pulley, let dry, reinstall belt and run engine. After it has chirped for a while, remove belt and check the pulley for polished-off paint on the tops of grooves, this indicates a worn pulley.
The Following User Says Thank You to RZNT4R For This Useful Post:
Diegov (08-20-2018)
Old 08-17-2018, 02:07 PM   #24
Ultramaroon
not playing cards
I've seen this a few times with rebuilt alternators reusing old pulleys where the edges of the belt bow up because of the uneven wear.
Diegov (08-20-2018)
Old 08-20-2018, 12:12 AM   #25
Diegov
So i squirt water on the belt and it stopped and came back so its the belt and what else should I tell her to replace for safe measures.
Old 08-20-2018, 12:22 AM   #26
DrButtDrugs
yerp
Drives: 2015 WRX
That's good news then. I'd replace the belt and see if any other problems arise, good chance that will correct the issue entirely. While you're replacing the belt give each pulley a wiggle and a tug to make sure it doesn't have any play and it spins true - anything short of perfect you should have a mechanic look at and get an informed opinion.
The Following User Says Thank You to DrButtDrugs For This Useful Post:
Diegov (08-21-2018)
Old 08-21-2018, 11:43 PM   #27
Diegov
Gotcha thanks guys for helping and for the advice as well much appreciated. I'll report back asap or whenever she replaces the belt thanks again have a great day/night guys.
Old 08-22-2018, 03:15 AM   #28
highway7
Drives: FRS 2013
Doesn't sound like HPFP.
Can be TOB, does noise change with clutch in/out?
You can try removing belt and turning each accessory or idler by hand and listening for a squeak
highway7 is offline   Reply With Quote
The Following User Says Thank You to highway7 For This Useful Post:
Diegov (08-22-2018)
Idle Noises (*Not Chirping*) tyynichols Issues | Warranty | Recalls / TSB 16 03-09-2018 09:37 AM
Engine idle chirping (cricket) noise poll. Hanzo Issues | Warranty | Recalls / TSB 5031 05-18-2017 10:41 AM
Engine idle chirping (cricket) noise poll. Hanzo BRZ First-Gen (2012+) — General Topics 229 02-16-2016 02:21 PM
Video of chirping at idle Julio86 Engine, Exhaust, Transmission 15 02-01-2013 11:37 AM
Anyone worried about chirping/idle/taillight condensation issues? JDM-dono AUSTRALIA 31 07-21-2012 02:12 AM
