Old 08-07-2018, 04:16 PM   #15
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by Clipping_Path View Post
Fixed.
The grounding wire had a little bit of white corrosion on it, scraped it off, lights on the left side were equally bright BUT...... still hyperblink!
So I unscrewed the left signal and took one more close look with a brighter flashlight and there was the tiniest specs of the same white corrosion on parts of the socket. Easily scraped it away with my key. Plugged the bulb back in - VOILA. Works again.
The right signal is probably not far behind - going to clean it as well.
Get some electrical contact cleaner and clean them thoroughly again then use dielectric grease on the contacts to keep it from happening again.
Also it wouldn't be a bad move to upgrade to LED turn signal bulbs and a hyperflash relay as you have valentis they would match perfectly
The Following 2 Users Say Thank You to FRSBRZGT86FAN For This Useful Post:
Clipping_Path (08-07-2018), humfrz (08-07-2018)
Old 08-07-2018, 09:51 PM   #16
humfrz
Electrical 101 - clean the contacts - I reckon that book got lost here lately -
humfrz
Old 09-07-2022, 12:03 PM   #17
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Originally Posted by Snifflepucker View Post
The driver's side headlight is often oriented somewhat lower than the passengers', although both should have the same intensity in non-HID lights.
Last post 08-07-2018.
Reported Because you are either a bot or too dumb to be on the internet.
The Following User Says Thank You to x808drifter For This Useful Post:
FRSBRZGT86FAN (09-08-2022)
Old 09-07-2022, 01:44 PM   #18
AHHHHH I was waiting for the link to show up. Now we will never know what they were selling.
Old 09-08-2022, 02:39 AM   #19
FRSBRZGT86FAN
Definitely a bot, google search shows the username being created on a ton of forums around the same time 17 hours ago and posting one line comments like these.
Also seems to like things involving lighting and replies to car forums where lighting things are involved
Old 09-08-2022, 08:01 AM   #20
Oh I had no doubt it was a bot. I just play a game with the "better" ones where I try to guess what the link that eventually shows up will be for.
Left Winjet headlight Mikeran Exterior Parts (Aero, Lighting, Etc.) 2 01-08-2017 12:51 PM
wtb: Stock left headlight trix202 Canada Classifieds 0 01-11-2016 07:05 PM
DIY: make DRL BRIGHTER without wiring or anything. Brighter Spec D booms VakaGT DIY (Do-It-Yourself) Guides 4 05-30-2015 01:36 AM
WTB: Driver (Left) headlight FRS/BRZ rayspeed Want-To-Buy Requests 5 03-02-2015 10:39 AM
WTB: Left Headlight BRZ or FR-S ecocyber Exterior Parts (Aero, Lighting, Etc.) 2 02-03-2013 04:01 PM
