Old 07-10-2018, 02:31 PM   #15
bfrank1972
Drives: 2013 FR-S Argento
Originally Posted by 86TOYO2k17 View Post
JDL has both, and they are the best performance for under 1k with quality sound.
Ace is only EL but all around best header, even bang for buck.
Seems pointless to buy a header back for purely only sound. Might as well get some performance gains out of it.
/close thread
/open thread (lol I can do this all day )
YMMV. Personally sound is a much more important consideration - when looking at all the quality headers (JDL, Ace, Ptuning, P&L, Tomei, Gruppe-S, Open Flash, etc etc) out there (EL and UEL) you're not going to see massive differences between them. Maybe 10ish lb-ft max in the lower rpm if you're cherry picking dyno sheets, and on average across the rev band it's less. Nothing is going to make the car a rocket, and in daily driving you're not going to feel a big difference. But you will hear a difference for sure.
bfrank1972 is offline   Reply With Quote
Old 07-10-2018, 03:10 PM   #16
FRS Justin
Drives: 2013 Asphalt FRS
Tomei has mastered the subie rumble with their UEL header and the quality is superb
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Old 07-10-2018, 03:19 PM   #17
FRS Justin
I disagree on the performance claims, A EL PPE header or Ace will out perform any UEL header by way more than 10ish lb-ft and the top end hp is way more.. If your looking for high performance go equal length if you want to hear that rumble UEL. It comes down to the driver, if the sound makes you happier than the spirted driving UEL is for you.
With E85 and a good exhaust setup your looking at 25 to 30ish hp difference with a proper tune. And that can get you into the upper 13s in the 1/4
710whp
Old 07-10-2018, 03:21 PM   #18
Impureclient
Drives: 2015 FR-S
I am going to take a dump so I'm closing this one back up again for a while. /close thread
Impureclient is offline   Reply With Quote
Old 07-10-2018, 06:17 PM   #19
86TOYO2k17
Drives: 2017 toyota 86
You should choose catback/FP based on sound, and header for performance. Unless your set on the UEL rumble even then get the best UEL performance.
Comparing tons of dynos and looking at before and after % increases not just number differences or new peak numbers. The ace header not only performs the best it’s actually as good if not better performance to cost ratio. (Less knowledgeable about PPE on the 86 platform but i know they are quality company as well)
And even if it was only 10hp/ft lbs difference that is still a lot considering most ppl getting a header are staying NA, or maybe will add a charger later. Either way not much NA power to add after header/tune so you might as well squeeze all you can out of that.
/close thread
Old 07-10-2018, 08:15 PM   #20
coryandy
coryandy's Avatar
Drives: '14 SSM BRZ Premium
All these suggestions, but no one has even asked the OP what his tuning solution is? Is that included in the budget, totally separated, or already taken care of? How many of these headers can you run without a tune?
"To be without silver is better than to be without honour." - Norse Proverb
coryandy is offline   Reply With Quote
Old 07-11-2018, 07:53 AM   #21
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
none.
Old 07-11-2018, 09:40 AM   #22
bfrank1972
Oooh, jump on this:
http://www.ft86club.com/forums/showthread.php?t=128891
WTT: Tomei uel headers for EL headers 86Tony Canada Classifieds 6 07-27-2015 09:42 PM
Headers? IAm_Sarcasm Engine, Exhaust, Transmission 42 09-23-2014 01:53 PM
Injen SES Headers/ Agency Power headers Choong86 Engine, Exhaust, Transmission 10 12-27-2013 09:51 PM
wtb: JDL uel headers andrew5826 Engine, Exhaust, Bolt-Ons 2 10-29-2013 11:35 AM
Headers? FRSBRZGT86FAN Engine, Exhaust, Transmission 35 07-16-2013 11:03 PM
