Old 07-07-2018, 06:06 PM   #15
norcalpb
norcalpb's Avatar
I’ve had my Kartboy for 5 years now, it rattled at first but I did everything on this board and then some to finally get it quiet. I love it but would do IRP if I could do it again (although metal shift knob option only is meh).
I have a 2” shifter extension to counter the 1” drop of the short shifter and the notchiness. Mtec shifter springs are also a very cool and unique mod.
Old 07-07-2018, 06:37 PM   #16
humfrz
Oh, my …
I don't understand, do I have this right, you installed a short shifter then installed a 2" shifter extension to counter the 1" drop of the short shifter ??
If so, why for..??
humfrz
Old 07-07-2018, 07:21 PM   #17
norcalpb
norcalpb's Avatar
Oh, my …
If so, why for..??
humfrz
Haha yes that’s right.
Short throw shifters have a much longer linkage below the shift boot to minimize the required shifter throw. Even though my setup sits 1” higher than stock, the throw is still much shorter and shifts feel much more positive. Kinda like a more tame version of what IRP did.
Plus I can still shift with my arm on my armrest which is the biggest necessity.
The Following User Says Thank You to norcalpb For This Useful Post:
humfrz (07-07-2018)
Old 07-07-2018, 08:13 PM   #18
humfrz
OK, I got the picture … sort of like back in the old days
Besides, when the 1-2 shift gets stubborn, the longer shifter would give you more leverage ….
humfrz - needs a nap …
norcalpb (07-07-2018)
Old 07-08-2018, 12:14 AM   #19
RJasonKlein
RJasonKlein's Avatar
I have the following setup and highly recommend it:
  • TWM Performance short shift kit
  • Perrin rear shifter bushing
  • MTEC shifter springs
  • MTEC clutch spring
  • Whiteline KDT923 (differential outrigger)
  • Whiteline KDT925 (differential)
  • Whiteline KDT926 (transmission)
  • Whiteline KDT922 (crossmember)
  • Millers Oils CRX 75W90 NT
  • Spiegler braided clutch line, custom made-to-order
  • JMP Coachworks Alcantara shift boot
  • WC Lathe Werks copolymer teardrop shift knob
Here’s a link to the TWM Performance short shift kit for our cars:
https://www.twmperformance.com/short...-short-shifter
RJasonKlein is offline   Reply With Quote
The Following User Says Thank You to RJasonKlein For This Useful Post:
SkyeHack (07-19-2018)
Old 07-08-2018, 06:05 PM   #20
N1cotine
The Body Shop
Drives: 15 FRS 400hp
CAE
CAE ultra shifter is awesome.
N1cotine is offline   Reply With Quote
Old 07-09-2018, 12:35 AM   #21
churchx
churchx's Avatar
Drives: 2014 GT86
More expensive, IIRC also required cutting into mid-console. I didn't heard of as much rattling issues with it, but still IRP looks somewhat better choice in my eyes then CAE, at least if/when rattling will get sorted out. What i'd really wish would be converter from H gate pattern to sequential though
Old 07-09-2018, 07:09 PM   #22
15limited
15limited's Avatar
I've got one that doesnt rattle at any rpm, and its seemingly impossible to miss shift or gear lockout. CAE ultra shifter. About $1200 to my door and a month and a half wait if Hard Motorsports is out of stock. Shifting becomes knife edge like, exceptionally precise and firm, not for limp wristed drivers.
Sent from my SM-G950U using Tapatalk
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
15limited is offline   Reply With Quote
Old 07-18-2018, 09:29 PM   #23
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
The transmission bushing makes the transmission twist less during times off and on throttle. The Perrin shifter bushing removes slop in the gate pattern. The MTEC springs give more force to the shifter to make it return to neutral, which gives the effect of making the throws feel quicker and with some spring. Throws from 2 to 3rd and others that go from the lateral to the medial positions will feel the most dramatic. A heavier knob will aid in smoothness, as will some quality gear oil like Motul, Redline, AMSOIL.
I have a knob n lockout from Aliexpress. Anodized aluminum which feels great in the hand.
Is the shift knob from aliexpress one of the MCE/MICIEI knobs? Ive been looking at this one
https://www.aliexpress.com/item/Spee...ceBeautifyAB=0
SuperTom is offline   Reply With Quote
Old 07-18-2018, 09:37 PM   #24
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
https://m.aliexpress.com/item/328305...t.32830512061&
They were called MCE (machine cutting excellence) or something but these are them.
The Following 3 Users Say Thank You to Irace86.2.0 For This Useful Post:
ImADuck (07-18-2018), SuperTom (07-18-2018), Teseo (02-07-2023)
FS: Stock Short-Throw Shifter, Springs, and Rear Shifter Bushing bergy Transmission and Driveline 8 10-20-2016 09:57 PM
cae ultra shifter vs short shifter jdmblood Engine, Exhaust, Transmission 22 01-13-2016 11:19 PM
kartboy short shifter and rear shifter bushing install and review. FR-S UMB FR-S DIY (Do-It-Yourself) Guides 21 10-18-2014 01:41 AM
TRD Short Shifter Quick Shifter Scion FRS hirollaz Transmission and Driveline 3 04-15-2014 01:24 AM
BPS Short Shifter Alabang 86 Transmission and Driveline 8 09-02-2013 12:58 AM
