Old 07-02-2018, 10:40 PM   #15
mhiscott
Drives: 2013 FRS
I've got 50,000 kms (just over 30k miles) with oil changes every 3k kms. I don't buy that there'd be significant enough delta in ring condition etc to make a measurable difference this early in the engine's life when it's been well maintained.
Regardless of the engine will deal with a pressurized crankcase because it's physically more tight and in "better condition" doesn't take away from the fact crankcases don't like being pressurized as a rule, regardless of if it will take it at this point.
While I was originally leaning towards going back to VTA because numerous tuners and folks have suggested it, I almost wonder if it's just the safer advice to give people because it's easy to screw up a sealed system install if it isn't done correctly.
I also have a 2018 STI. It has a boost rated oem pcv valve which blocks intake charge air from getting into the crankcase. It's something like 3/8th NPT iirc. I don't see why I shouldn't be able to order a replacement STI valve at the dealer, thread it into a female NPT to male barb adapter, and put it in line with a sealed can on the PCV side. I could keep the OEM pcv in the block too, even if it's sort of redundant.
I don't see why the above setup wouldn't work a valve known to be reliable for multiple hundreds of thousands miles on OEM Subaru applications (insert joke here about no boosted EJ25 cars making it that far lol).
mhiscott is offline   Reply With Quote
Old 07-02-2018, 10:44 PM   #16
You're the one asking, I'm providing real world feedback. If you want a check valve or AOS, by all means! It won't negatively impact the performance of the car at all.
Old 07-02-2018, 11:24 PM   #17
mhiscott
Drives: 2013 FRS
I think it must be something else about our setups that must be different, but I can't think what it could be. Your PCV valve must be working well, it would be interesting to see how it seals up with various psi values on a test bench with compressed air.
I am leaning towards trying a sealed setup with a FI proven OEM valve. Worst case scenario, I could convert them to VTA if I have issues. I realize VTA is a safer bet, but I feel strange discounting sealed setups without explicit reasoning for why VTA is a better option than a properly setup sealed can. This is assuming a reliable boost isolation method is used.
FS: Hawk track brake pads, DTC-30 front/HP+ rear, 90% life left, best track day combo tampaSi Brakes, Suspension, Chassis 4 05-27-2017 02:31 PM
MVP Track Time 2013 Great Lakes/Midwest Track Dates Feffman Great Lakes 5 09-07-2013 01:39 PM
Track Day: Upcoming Joey G Open Track Day for ADVANCED Drivers, Aug 20 NJMP Lightning AZP Installs NY / NJ / CT / PA 11 08-20-2012 11:31 PM
Track Day: Upcoming Joey G Open Track Day for ADVANCED Drivers, Aug 20 NJMP Lightning AZP Installs Tracking / Autocross / HPDE / Drifting 0 08-14-2012 06:46 PM
Element Tuning Track Tested and Track Proven FRS Video Element Tuning Tracking / Autocross / HPDE / Drifting 47 07-17-2012 04:12 PM
