Old 08-23-2018, 08:47 AM   #15
steve99
Originally Posted by jRuN View Post
Are the older tunes available to download still? I just got my OFT so the tunes i received from them are the v4.03 versions. I have been driving it for a couple days now and a couple things for me.
1. I most definitely have the throttle deadspot .. feels like i can push the pedal in a half inch or so before any throttle input is registered.
2. I took a datalog.. i pressed record and rev'd out 3rd gear from about 3k RPM all the way to redline and then let off. In the log.. the throttle input only reached 96% and actually kind of tapered off towards the end of the rpm range. I found this to be a little odd.. I will be trying to do another log tomorrow to see if i get the same result.
3. I'm not sure about this "quiet idle" you guys are talking about? When i cold start .. the engine rev's up to a higher rpm.. and then after 30 secs or so drops down to 700ish rpm. What is the quiet start RPM you guys are seeing on cold start?
4. Speaking of idles.. idle was pretty solid the first day but i've actually noticed today that mine is now bouncing around a little bit while at stop lights.. it will drop and then almost stutter a little bit and then bounce up higher.. and settle back at 700.. and then repeat that. A/C is ON btw.. (live in FL)
So.. that's kinda my situation.. not sure what's up.. gonna keep driving and logging and experimenting i guess.. but i've done no modifications to the tune.. just straight from OFT.
Originally Posted by freerunner View Post
Had the same problem here. Idle is too lean. Can't be resolved via maf scaling, though. One possibility is to edit the front o2 sensor scaling. There are probably other tables to correct these conditions but I haven't dug into it yet.
Check you dont have exhast leaks you usually get high positive ltft at idle
Check intake leaks you want to see boost parameter at about -9 psi ie vaccuum at idle or about 0.3 bar, think oft works in psi and measires 0 boost at atmospheric pressure ie 1 bar 14 psi. But i think oft boost parameter is reliative to atmospheric not absolute
If all good then try running full di injection at idle loads ie put zero in the 0.2 and 0.3 load columns in the thre di\di ratio tables
Still no good alter the idle conpensation tables this determines how much advance\retard is used to control idle speed thtese tables are defined
Old 08-24-2018, 09:25 AM   #16
Kodename47
Kodename47's Avatar
Drives: UK GT86
You could try enriching the CL fuel table at idle loads.....
.: Stealth 86 :.
Kodename 47 DJ:
Old 08-24-2018, 09:33 AM   #17
Tor
Tor's Avatar
Drives: Toyota GT86
Or add fuel through the Engine load compensation table. It idles in 0.2 and 0.3 bar.
Tor is offline   Reply With Quote
Old 08-24-2018, 10:21 AM   #18
Kodename47
Kodename47's Avatar
Drives: UK GT86
It would closed loop that out
.: Stealth 86 :.
Kodename 47 DJ:
The Following User Says Thank You to Kodename47 For This Useful Post:
tomm.brz (08-24-2018)
Old 08-24-2018, 11:50 PM   #19
jRuN
Here's a log i captured while my idle was bouncing around. What does your expert eyes see here ??
https://datazap.me/u/junnever/log-15...data=1-9-10-11
jRuN is offline   Reply With Quote
Old 08-25-2018, 01:31 AM   #20
steve99
looks like ecu is compensating for something using ignition advance
log boost it will show manifold pressure/vaccuum
is air conditioning or defrost or defog on as that will cause idle fluctuations
what mods do you have ? intake or catchcans or anything else
do you have any aftermarket electrical stuff like headlights ?
Old 08-25-2018, 09:15 AM   #21
jRuN
A/C is ON. Bone stock other than Valenti tail lights.
Sent from my Pixel XL using Tapatalk
Old 08-25-2018, 12:09 PM   #22
Tor
Tor's Avatar
Drives: Toyota GT86
If it's running lean, I suppose it was meant that it runs off target AFR? Didn't have the problem, so can't say if it will help. But it might be worth a try.
Old 08-25-2018, 07:46 PM   #23
Kodename47
Kodename47's Avatar
Drives: UK GT86
Seems that some setups like a little enriching at idle. It isn't this platform specific. Certainly stopped mine from bogging.
.: Stealth 86 :.
Kodename 47 DJ:
Tor (08-25-2018)
Old 08-25-2018, 10:52 PM   #24
steve99
A/C represents a reasnoble load on small engine ,
try bumping base idle setting up by 50 or 100 rpm
Old 10-21-2018, 11:45 PM   #25
Viper8
Drives: Scion FRS
So I finally flashed the new Stg-2-plus-v4.03 tune (I was running the OFH v1 tune prior) to see if I could feel any differences. After giving the car about a week to settle into the new tune, I noticed more throttle lag than previous, and the car seemed less responsive at all throttle ranges. I logged a few 3rd gear pulls and noticed am at 0.7 with minor flkc corrections.
This worried me at first that significant knocking was initiating an am drop from 1.0 to 0.7. I finally sat down and decided to delve into the differences between the OFH v1 tune and the new Stg-2-plus-v4.03 tune and here's the highlights...
284 same tables
19 changed tables
38 new tables
As for the changed tables, the significant differences to the v4 tune include:
Initial am at 0.7 vs 1.0 (causing the laggy feeling)
Base timing b table timing reductions above a load of 0.7 and 3700rpm
Start-up idle speeds were decreased
A/F learning limits were narrowed down
Overall, it appears the new tune is more a more conservative replacement. I miss the response so I plan to adjust the initial am back to 1.0, make a few other minor updates, and do some logging.
Viper8 is offline   Reply With Quote
Old 10-29-2018, 03:49 PM   #26
BOND007_LTK
Drives: 2013 brz
284 same tables
19 changed tables
38 new tables
Please do let us know your quest to tune to 1.0 IAM.
There was quite a length discussion around here on the forum for why it was set to 0.7 and not 1.0 and lots of flaming.
After driving for quite some time with all the different tunes, it makes sense that IAM should be at 1.0. The whole point of tuning is to make the car perform (fairly generally speaking) to the max of its potential. It's not difficult to consistently get the same octane of gas, let alone the same brand name too.
If it were 0.9 IAM, I understand, but there's no differentiation in 91 and 93 octane with the newest tune.
Anyone have mapping for 93 octane gas for the latest OFT tunes?
BOND007_LTK is offline   Reply With Quote
Old 10-31-2018, 11:00 PM   #27
Viper8
Drives: Scion FRS
Sure thing. I flashed the customized v4 tune (including IAM back to 1.0) yesterday. I'll post impressions and logs after the new tune settles in in a week or two.
Old 11-01-2018, 01:40 AM   #28
Mr_Eyo
Drives: 2017 Toyota 86
Not OP here.
I set my IAM to 1.0 and had to pull about 3 deg out of the OTS Stg1 v4.03 tune base timing table B at high load around 4800 rpm. Been compketely knock free and don't have that dead pedal feel. I only use California 91 from Valero (also elimnates crickets!).
Mr_Eyo is offline   Reply With Quote
OpenFlash Headers in 2017 &a Tune -- success & no tune yet gskv Software Tuning 151 03-29-2018 09:10 PM
B01D 6AT SBD Turbo Tune Questions *Tune Attached* Pro60modman Software Tuning 6 09-05-2016 10:04 PM
How can you trust a tune? (tune noob) Benschneider06 Software Tuning 20 05-21-2015 12:03 PM
Drift Office Tune vs Visconti Tune mechaghost Engine, Exhaust, Transmission 109 07-03-2014 01:57 AM
difference between vortech tune and perrin tune? Frs32907 Forced Induction 7 12-05-2013 03:49 PM
