Old 06-01-2018, 07:56 PM   #15
steve99
Originally Posted by Muchikori View Post
Yeah only one definition is on my Rom Raider.
I just wanna make the car faster as these are some of the similar changes i did to my Mazda when i was tuning it. sorry iknow those are 2 differnet platforms.
Would you be able to give me advise as to which tables should i modify in order to squeeze out some power from a drop in filter + inlet tube?
OK
I think your problem is you changed the FFS delta parameter to 7000.
this means the FFS rpm will be redline ie 7600-7000 ie 600 rpm. This if you push the clutch its going to activate FFS at any rpm over 600 this will pull fuel and cause car to stall
Set the FFS delta back to ZERO.
Also your fueling and timing changes look a bit wholesale suggest as @Kodename47 said you just correct maf scaling if needed and take some logs you cannot just lean it out and add timing to find power, everything interacts. Im not sure what basis your making large changes to cam timing either if you have stock header
Dash Cam: Hot Lava FR-S Hops Curb 3 times in Hit and Run gkubed FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 13 03-26-2017 05:43 PM
Consensus on changing whole transmission versus changing solenoids dem00n Engine, Exhaust, Transmission 7 07-20-2016 03:50 AM
Rocket Bunny V1 Question Brody602 Cosmetic Modification (Interior/Exterior/Lighting) 4 09-14-2014 06:18 PM
Rocket Bunny Question rayted24 Scion FR-S / Toyota 86 GT86 General Forum 7 02-27-2014 12:31 AM
Hops Normal's White FR-S Hops Normal Member's Car Journals 8 01-06-2013 03:00 PM
