Old 05-27-2018, 02:28 PM   #15
Jasonb
Drives: 17 Series Yellow BRZ
Does the stock tune reset to .7 on each startup? I haven't been on one for a while and never checked.
Yes, .7 on each startup
Jasonb is offline   Reply With Quote
Old 05-27-2018, 03:39 PM   #16
Lantanafrs2
Drives: 2013 frs red
172 sounds like you got a good one.
Old 05-27-2018, 08:39 PM   #17
steve99
unless it was already lower than 0.7 :-)
ecu uses iam initial value at startup, unless the iam value after last drive was less than iam initial.
Old 05-28-2018, 08:35 PM   #18
Lantanafrs2
Some days I wish this thing had a softly tuned bigger motor in it so I wouldnt have to brake drag it to get the iam back. Knock sensor shit . I guess it would make me less of an "enthusiast" though.
Old 05-28-2018, 08:46 PM   #19
wparsons
wparsons's Avatar
Yep. It might not revert on a hot restart, but definitely if parked for a while.
flickr
Old 05-29-2018, 10:03 AM   #20
ermax
ermax's Avatar
It will reset even on a key flick while rolling. As steve99 pointed out, it will only reset if the IAM climbed above the initial. If it was below the initial then it will restart at the lower value.
Old 06-03-2018, 12:53 PM   #21
nico_rsx
Drives: BRZ 2017 Pure Red, MT
I just learn reading this about the 0.7 IAM. Is it only on the 2017?
I do autocross a lot with my 2017, and often stop the car between runs. This would mean i lose a lot a HP in the following run!!
How much time does it take to go back from 0.7 to 1? Does it come back after the first pull in first gear? Does that pull need to be to redline? From the start line I usually shift to second at 6500rpm, since I reach the first slalom before redline. Is that enough to go back to 1.0 IAM?
And is there a way I can monitor the IAM without an Ecutek or OFT? I have a OBD2 reader. Maybe I can check the timing advance and deduce the IAM?
Thanks
nico_rsx is offline   Reply With Quote
Old 06-05-2018, 11:25 PM   #22
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Was the negative battery terminal pulled; ie was the ECU reset, and it needed to learn?
Where to go for quick dyno runs? TM Northern California 1 07-27-2015 06:53 PM
FREE Dyno runs when you buy a Tune/Flash vividracing Arizona 0 05-19-2015 05:43 PM
Kraftwerks Supercharger - Time-lapse of install + dyno runs. The Sentinel Forced Induction 1 02-06-2015 09:04 PM
Baseline Dyno runs at VIP performance: 2015 FR-S sachu Engine, Exhaust, Transmission 0 01-10-2015 10:32 PM
My Dyno Runs Crewzern AFRICA 4 10-30-2012 03:52 PM
