Old 04-20-2018, 02:23 PM   #15
power doesnt chance your balance.
Get some stickier tires first.
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
strat61caster (04-20-2018), Strife26 (04-20-2018), wparsons (04-20-2018)
Old 04-20-2018, 03:41 PM   #16
Strife26
Strife26's Avatar
Drives: 2015 Subaru BRZ Series.blue
Right, but anything to spin less. It can spin shifting in 2nd, 3rd, and 4th with the boost. I haven't had issues with losing control, but could easily do so if not paying attention. I was hoping for all possibilities in lowering that breaking free of traction, especially so easily. I figured tires would be the first and most recommended, and I will be getting stickier tires once it is out of the shop, but beyond that what would be the next item to work on/research?
Again, thanks for the responses/discussion @ all.
Please only adult answers.
I'm stupid, retarded, a fkn idiot, and I will kill myself after a couple answers, I already know this (thanks to the interwebs and its logic) so feel free to leave those responses out, thanks.
Strife26 is offline   Reply With Quote
Old 04-20-2018, 04:04 PM   #17
Racecomp Engineering
Good tires, good alignment, and drivers education (which is something all of us need more of).
There are shock adjustments that could be made to cope with lots of power, but they may or may not be a net positive for you and not all shocks have the adjustability/consistency to reliably dial that in. That's still only a small part of your issue.
Get the basics right first. Your issue is not a "not enough parts" issue.
- Andrew
The Following 5 Users Say Thank You to Racecomp Engineering For This Useful Post:
churchx (04-20-2018), strat61caster (04-20-2018), Strife26 (04-20-2018), wparsons (04-20-2018), x808drifter (04-20-2018)
Old 04-20-2018, 04:41 PM   #18
wparsons
wparsons's Avatar
That is going to depend heavily on what you want the car to do. Drag suspension will greatly help with grip in a straight line, but you'll be giving up lots of cornering ability.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
Old 04-20-2018, 05:29 PM   #19
Strife26
Strife26's Avatar
- Andrew
Yes sir! Getting alignment from the shop, and will be getting new tires asap, which I should have done a while ago. The ones I threw on there were cheap and likely garbage (No brand/model out of fear, lol). I just didn't prioritize tires over the other items I've been working on/adding.
Recommendations for best bang for buck roadster/windy back roads tires?
The Following User Says Thank You to Strife26 For This Useful Post:
Racecomp Engineering (04-20-2018)
Old 04-20-2018, 05:32 PM   #20
churchx
churchx's Avatar
Drives: 2014 GT86
cjd: not only perfect drivers are needed, but also perfect road surface .. which is rare mythical beast rarely seen even on track and almost never on badly maintained public roads. Even more so in winter with snow/ice thrown in mix.
In my eyes having slight rear toe-in's on RWD cars pros outweight cons 90% of a time, both on track & DD. It made car much easier to drive/control under throttle both coming out of corners on track at higher exit speeds and simplified driving in winter instead of nervous balancing on edge with throttle & countersteering with often messing up (though i admit, that maybe less toe-in was not only culprit, it might be also bad uneven between sides stock alignment too, as most often under throttle car tended to oversteer rear to one side. I should have asked initial stock alignment numbers for reference, but forgot).
Of course, everything depends on dose and medicine may turn into poison, and excessive toe will quickly grow cons like car not willing to rotate, being more numb, and with excessive tire wear and fuel mileage dropping, making cons outweighting pros. Balance/art of suspension tuning i guess.
The Following User Says Thank You to churchx For This Useful Post:
cjd (04-20-2018)
Old 04-20-2018, 05:35 PM   #21
Strife26
Strife26's Avatar
Still want my stock experience with a bit more oomph.
Old 04-20-2018, 05:36 PM   #22
norcalpb
norcalpb's Avatar
Pilot super sports are pretty sweet if you care about comfort, but I think your current spring rates would expose the sidewalk flex on a canyon run imo, especially doing auto x or track.
I just got Federal RS-RR and they have so much grip but I sound like a divebombing ww2 plane because of how much noise they make. I think you’ll want to do something similar to this tire to get the grip you want during boost. $400 for the set lol.
The Following User Says Thank You to norcalpb For This Useful Post:
Old 04-20-2018, 06:32 PM   #23
How much power do you make?
At 450 crank hp, I can't spin 2nd with 265 MPSS when they're warmed up.
wparsons (04-22-2018)
Old 04-20-2018, 06:58 PM   #24
Strife26
Strife26's Avatar
I haven't dynoed yet. A guy with a very similar setup (same kit) was pushing about 280 whp.
I'm looking at:
245 - 255/35-45/18
Hankook Ventus V12 evo K110
Firestone Firehawk Indy 500
And the MSPSS
Feel free to suggest sizes or anything else. I haven't had my car for 1-2 months now and I think I'm even dumber than I used to be, lol.
Old 04-22-2018, 12:29 AM   #25
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
I'm looking at:
245 - 255/35-45/18
And the MSPSS
If any of those are an upgrade from what you're currently running, then that's the problem right there.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
venturaII is offline   Reply With Quote
The Following User Says Thank You to venturaII For This Useful Post:
Strife26 (04-23-2018)
Old 04-22-2018, 01:16 AM   #26
strat61caster
strat61caster's Avatar
https://www.tirerack.com/tires/surve...ue&type=MP&VT=
https://www.tirerack.com/tires/tests...et?perfType=MP
Continental Extremecontact Sport doesn't show up on that chart for some reason, but should be better than the MPSS
ineedyourdiddly
Looking for OEM suspension and Rear Suspension Lateral Link Rod jprules Want-To-Buy Requests 1 01-06-2018 12:43 AM
OEM suspension and Rear Suspension Lateral Link Rod jprules Want-To-Buy Requests 3 10-04-2017 07:56 PM
Suspension Super Sale ISC Suspension | KW | Tein | Cusco and More OCRaceShop.com Brakes, Suspension, Chassis 14 08-26-2015 11:43 AM
Squeaking / Creaking rear suspension with low ride height? Suspension pros welcome! mothespaceman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 08-14-2015 06:06 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 09:15 AM
