Old 04-14-2018, 06:08 PM   #15
mrg666
pessimistic skeptic
mrg666's Avatar
11-12 seconds is telling you that your engine is not running efficiently. I would replace spark plugs (maybe coil packs too, ask your dealer) and have an injection cleaning service. I would also check air filter and replace it if dirty. Automatic transmission should be okay, it is a very reliable one. Your mpg should be low too although you might not care about it in Dubai. Good mpg means efficient and powerful engine.
Old 04-15-2018, 02:25 AM   #16
darksnyder
Drives: 2013 Toyota 86 (Hot Lave)
You're correct about the mpg. I noticed reduced mpg as well. which happens to coincide with the date i got the oil changes and the air filter installed. Got it installed on the 17/03 and since then a drop in the mpg can be observed.
I have a doubt on the air filter. Although its relatively new, so shouldn't be dirty, will check it anyways. But it might be possible it is a dud.
darksnyder is offline   Reply With Quote
Old 04-15-2018, 08:58 AM   #17
gravitylover
Originally Posted by darksnyder View Post
Haha yes indeed, they have seperate licenses for AT and MT. Though MT can drive both.
But due to this, buying an MT becomes a very big drawback here. Usually we switch cars with buddies, like if I need practicality I will exchange with my 2 door coupe with my buddy who has a 4 door sedan. So as almost everyone has an AT license, it becomes a handicap if you get yourself a MT. Cant trade with buddies, wife cant drive, and so on. And hence, poor resale values of MT as well.
A used '13 86 MT might run a difference of up to $2,000 as compared to similar AT.
How is it determined which license you qualify for? I assume there's a different road test for each type of license. Can you go from an AT to MT license easily or are you stuck with the AT license once you've gotten it?
Off topic I know but it's the same in Australia. I don't see the joke regardless of how poorly it's told..
How is a person supposed to acquire the proper license if they're not able to go out and drive an MT car? Are there special 'training centers' or can you only go on private property? Do you then have to take a special road test that's different than the one for an AT license? The bad joke part is, 35 years ago as a teenager when I started driving, there would have been no way for me to learn to drive a stick in the suburban hell where I lived if I couldn't just go get one and start figuring it out in traffic. I don't think there's any good way to learn other than to throw yourself into the fire and make it happen.
Old 04-15-2018, 10:00 AM   #18
darksnyder
[quote]
Actually there is no criteria on how a person is determined if he can drive a MT or AT. It is basically what you apply for. So when you apply for a new license, you have the option to choose AT or MT. Then the classes and the test are scheduled accordingly. Most of the classes are same, apart from the initial ones where they MT have to go through additional classes over clutch control, shifting, stalling, etc. And there are a few additional checks in the final exam for the MT as opposed to AT, like shifting in to the right gear, not stalling, etc.
The main reason for going for AT is that obtaining a license in Dubai is difficult and pretty expensive. It common to hear people failing 3 or 4 times before getting the license. So everyone takes the safe route, just worry about lane change and positioning and not worry about shifting gears. I got mine in first attempt and it cost me around USD 1,500.
And yes, you can shift to AT to MT anytime by taking a few additional classes and giving the road test again.
Old 04-15-2018, 03:08 PM   #19
darksnyder
UPDATE: Did another run today with all nannies off, manual mode. Outside temp around 32 degrees C. Fuel tank was full though. Still average around 11 seconds. Talked with the garage owner, have an appointment tomorrow.
Old 04-15-2018, 03:53 PM   #20
Kodename47
Kodename47's Avatar
Drives: UK GT86
It's the same here in the UK. Dubai inherited many road laws/legislation from us I believe so that's why they have the same. Pass your test on an auto, you can only drive an auto. The only reason that people here do that is that they can't deal with changing gears, I know no-one that has an auto license.
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-16-2018, 11:57 AM   #21
darksnyder
Update: Went to the garage. The air filter was clean. The guy test drove the car and stated that the issues seems to be the with the DI. Although its not bad as some other cars, but there is slightly something off with the DI. So in short he has recommended changing the injectors before it cause damage to the engine*sigh*. Waiting for the quotation, in the meanwhile just got the MAF cleaned and took the car home.
Noticed one more thing. There is a slight stutter you can call it during the lower RPMs. At the higher RPMs it seems to be fine. Especially cruising at 5th or 6th gear, around 2.5k RPMs and then accelerating, the car would stutter and you can actually see the RPM needle fluctuate +-200RPMs. edit: found a video pretty similar, although not as aggravated as his :
[ame="https://www.youtube.com/watch?v=1wKQJfk9qRg"]Toyota gt 86 rpm rev flickering during acceleration brz frs - YouTube[/ame]
My 90,000km major service is also due soon. Further, I am also planning of getting the Borla UEL plus the stage 2 tune as well after a month.
Now the question is the garage owner ruled out the injector cleaning. He says it just BS. However the toyota dealer offers an injector cleaning service for about $100. Is that any good? Can I top that up with changing the spark plugs, leave it as it is for now, defer the inevitable for a month and combine everything with the 90k service + headers + Ecutek?
Old 04-16-2018, 02:21 PM   #22
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
Not sure in Dubai but the injector cleaning here in the states is BS. They just put some shit in your fuel tank then charge you too much $.
Looking at your video something is clearly off without a doubt. I would get an obd2 adaptor and connect a phone or laptop and check the stats. See if a code is thrown, that may point you in the right direction as to what's causing that rpm fluctuating.
DandoX is offline   Reply With Quote
Old 04-16-2018, 02:48 PM   #23
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
2.5k in 5th or 6th and romping the loud peddle means you're asking too much of it.
Shift down. Geeze. Sure it's going to knock.
That sort of rpm would be fine for a diesel, but that would be knocking too, "Because Diesel".
Old 04-16-2018, 03:09 PM   #24
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
don't think so, OP is driving an auto & going WOT in 5th or 6th even around 2.5 Ks in either MT or AT shouldn't really do any harm...
HKz is offline   Reply With Quote
Old 04-16-2018, 03:22 PM   #25
bcj
Geo Tyrebighter Esq
bcj's Avatar
Torque converter would be locked up, no different than manual.
It'll lurch and sound weird like any other over stressed machine.
Shift down. Even get the free rev-matching - WOOT!
Old 04-16-2018, 03:33 PM   #26
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
This motor knocks a lot around 3k. It's not good to lug it in that range.
OP. I'd have it checked for codes, you have something abnormal going on. Does it pop at idle or anything weird on startup?
Old 04-16-2018, 04:08 PM   #27
Lantanafrs2
Drives: 2013 frs red
That thing isn't right. I'm surprised no cel
Old 04-16-2018, 04:35 PM   #28
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
That is not the OP's video.
shiumai is offline   Reply With Quote
Twins are slow? Not as slow as these cars! babydriver Scion FR-S / Toyota 86 GT86 General Forum 66 12-12-2014 12:09 AM
FI Guys: Were you more excited when you bought your car, or when you bought boost? husker741 Forced Induction 28 02-25-2014 03:57 PM
Best store bought or online bought wax ThatManAnt Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 16 03-12-2013 09:32 PM
people are unusually nice on this forum dnL Scion FR-S / Toyota 86 GT86 General Forum 114 02-07-2013 12:43 PM
North Korea issues unusually specific threat Exhaust Off-Topic Lounge [WARNING: NO POLITICS] 7 05-19-2012 12:12 AM
