#15 |
Drives: 92 lexus sc300 > whiteout MT FRS
I just had my 2013 engine rebuilt with 62k under Toyota extended warranty, total bill was $11,602, the service agent told me that a new crated FRS engine was $6500. I was lucky Toyota did the right thing by honoring my warranty.
#16 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
[QUOTE=spdsk8race;3068648]My big question is should I get it towed to another shop, since the dealership won't do a teardown to find the actual issue without a warranty, trust the dealership, or find my own engine which I have no idea where to start on that. Toyota told me because my oil records are from jiffy lube they are valid to a out of warranty fix. Only dealership records will be accepted.[/QUOTE]
Valid to out of warranty fix? What do you mean by that? And like said, read your manual. You have a right to have the car serviced by anyone and you also do not have to use OEM parts/fluids. https://www.consumer.ftc.gov/article...ne-maintenance |
#17 |
I had oil changes from Jiffy lube and my local independent Honda shop beside me do oil changes at 7500 miles interval and Toyota honored my warranty. I believe you can do your own oil changes as long as you have all documents.
#18 | |
Drives: scion frs
[quote=finch1750;3068809]
They said they wouldn't do a out of warranty courtesy because it was serviced by jiffy lube. I talked the dealership today and told them I was going to be towing the car to a nearby shop who quoteed me 6k for a used engine 23k miles and labor with a one year warranty. They told me that they could possibly come under that. Which is a big difference from the 17k they originally stated. |
#19 |
Drives: BRZ Limited; GR86
Bought an engine with 15k miles for $2600 shipped. Labor will run you anywhere from 1-2k so you're at around $4k
#20 | |
Panda Trueno
Drives: No twin now.
[quote=spdsk8race;3069046]
Seriously, get a second opinion.... you very likely could not even need an engine replacement, just a sensor. Did you take a look at the various fixes for that code by any chance? |
| The Following User Says Thank You to Summerwolf For This Useful Post: | humfrz (04-06-2018) |
#21 | |
TRACKBREAD
That's a much better prospect already! That said once your car is all better again, don't take it to Jiffy Lube or other 10-minute oil change places. The oil they use is shit, IF they even change it. They likely don't change your filter either. Do some googling, there are some horror stories out there. I'm not surprised the dealer refuses to own the warranty on a car serviced there. Either take it to a good independent shop or do it yourself (it's really not hard and takes ~1/2 hour) if you don't feel like paying the dealership's price for an oil service. It's too important to leave up to chains that are known to take massive shortcuts at best. Sent from my iPhone using Tapatalk |
| The Following User Says Thank You to Yoshoobaroo For This Useful Post: | 22R (04-07-2018) |
#22 |
Drives: 2013 FR-S Series 10
I took my old 2000 Accord to Penzoil for oil changes from 40k to about 250k. Never had a problem with them. I did watch them do the work usually. They'd also always try to upsell all the other bullshit (air filters, trans flushes, coolant flushes etc) but that comes with the territory. Not all those places are bad.
I've since moved away and haven't found a decent similar place so i've been taking it to a independent shop and they charge damn near as much as the dealer for oil changes. And last time they installed a leaky bosch oil filter. might as well just go back to the dealer. |
#23 |
Drives: Brz
For my personal knowledge, on the oil picture of OP, what does represents the metal flakes? Is it in the center of the light spot where there's sort of a color gradiant (brown towards grayish) or it's the bright white sparkles all around?
I had an oil change looking like the bright spot and I was concerned but also did'nt know what metal flake looks like. thank and good luck to OP! |
| Advice about dealership mishap! | ModalSoul37 | BRZ First-Gen (2012+) — General Topics | 16 | 10-21-2014 07:30 PM |
| Dealership overfilled my engine oil | mike the snake | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 50 | 12-07-2013 10:50 PM |
| Need some advice (dealership error) | Dreamshot | Scion FR-S / Toyota 86 GT86 General Forum | 19 | 06-09-2013 09:32 AM |
| Dealership advice | MattZ28 | Southeast | 6 | 01-06-2013 01:36 PM |
| dealership 4 hours away, bad for engine break in? | Mykflo | BRZ First-Gen (2012+) — General Topics | 27 | 05-23-2012 07:57 PM |
