#15 |
Drives: 2016 FR-S Asphault MT
yup i fit 17x9.5 +20 and slammed it with the stock 215 tires. ZERO RUBBING.
no fender mods, plastic still intact. yes im on coilovers and i had to camber the front SLIGHTLY. but its not all stance boi (at least not to me, maybe 4 or 5 deg negative). since you are on springs (i assume you aren't going coilovers?) and about to add the camber bolts... i would highly recommend checking your tire clearance from the spring now. if you are already close, camber bolts will make it closer. another option is just getting adjustable camber strut tops. pricey, yes but more adjustment from the top without decreasing spring/tire clearance. for example: http://www.raceseng.com/cascam-caste...ubaru-brz-2013
| Might just be me,just want to make sure | Grimm0ne | Issues | Warranty | Recalls / TSB | 6 | 04-30-2015 09:18 PM |
| They Don't Make 'Em Like They Used To | Tcoat | Other Vehicles & General Automotive Discussions | 30 | 01-25-2015 09:06 PM |
| You can't make this up | meeskee2 | BRZ First-Gen (2012+) — General Topics | 5 | 03-18-2014 11:14 AM |
| Just want to make sure | Moonbase | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 04-16-2013 04:02 PM |
