CANADA Canada
Old 04-12-2018, 01:26 PM   #15
n0thing
Drives: Subaru BRZ
Physics don't lie, but machines can be out of calibration, then the numbers are off. You can have your alignment checked at different shops, back to back, and I'm sure the readings would all be different. Which one is correct? How often do you think shops hire a Hunter technician to come in and calibrate their alignment rack? Think beam vs click torque wrench.
Having said that, I settle for laser alignment and click torque wrench, due to time.
n0thing is offline   Reply With Quote
Old 04-12-2018, 05:01 PM   #16
Frost
CASC-OR T.A. Director
Frost's Avatar
Drives: '13 Prius, '22 BRZ
The laser alignment is designed for far easier calibration over time and less likely to lose calibration over time as well with proper care and maintenance.
User negligence will lead to erroneous readings whether with a string or a laser. If the same competence is used when using the string or laser, the laser should be more accurate all the time.
On that same note, if you want to throw lack of maintenance as a factor, then how often are the rules and string being used check for tension and physical wear and tear?
It just seems like a red herring statement to make.
I am not here to diss the string method as it does use very basic geometry and ingenuity to pull off but calling the laser method less accurate is not right either.
Want the best quality track times for new personal bests? Come on out to Ontario Time Attack!!!
OTA LIVE TIMING LINK
Frost is offline   Reply With Quote
Old 04-13-2018, 10:11 AM   #17
wparsons
wparsons's Avatar
Strings also require very precise setup every time, and are based in some level on the frame of the car being square/true.
Every method can be flawed if not used right.
flickr
Old 04-16-2018, 03:42 PM   #18
laksman91
Drives: BRZ Sport-Tech, Evo X GSR, E92 M3
Driven in Markham has been doing my alignments for last year’s track season. Was happy with the end result.
laksman91 is offline   Reply With Quote
Old 04-16-2018, 04:09 PM   #19
Tokay444
Anti stance.
Tokay444's Avatar
Can-Align in the Cambridge area is a racecar shop. They'll give you exactly what you ask them for.
http://www.canalignment.com/
Old 04-17-2018, 03:03 PM   #20
wparsons
wparsons's Avatar
Even better/more important, if you don't know what you want Scott will give you a REALLY good starting point based on your driving style, experience, etc.
flickr
Old 04-20-2018, 04:58 PM   #21
JoeyBareBones
Drives: 2017 BRZ Sport Tech
Originally Posted by Rakshaa View Post
@FT86Z I don't know about Markham/NY but APEX Motoring in Mississauga (right off 401/Dixie) was great to deal with for me. My 86 is slightly lowered on TRD springs for reference.
I'm on trd springs as well. What were your alignment specs?
JoeyBareBones is offline   Reply With Quote
Alignment settings/Alignment Shop v1beeee CANADA 27 04-24-2017 04:54 PM
Camber/alignment for Eibach Prokit and when should I get alignment? Meanderchap Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 02-01-2016 03:44 AM
Alignment Johnny. Southwest 7 03-19-2015 10:07 PM
DIY alignment - quick way to set alignment while new suspension settles? 1Cor10:23 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 12-11-2014 09:53 PM
Just got an alignment.. Scalzo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 30 06-01-2013 10:39 PM
