Old 08-11-2019, 10:37 AM   #15
ls1ac
ls1ac's Avatar
I had this same problem and found the problem was with the OBD plug and the cable. The simple solution for me was to get an extension cable and all was good again.
Old 08-15-2019, 12:01 AM   #16
sroby
Drives: 2015 Firestorm 08/05/15
I had to do the same thing, bend the pins ever so slightly it tightened it up and I was good to go.
sroby is offline   Reply With Quote
Old 08-29-2019, 11:28 AM   #17
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
It should go green whether plugged into a car or not. If not, try a different USB port, or run update to make sure the cable is up to date (the firmware occasionally requires updates). You may need to uninstall/reinstall. Also depowering the cable for a few minutes and trying again can help. You can also try a different PC (even if it is a desktop you have no intention of using for flashing) and see if it will work on that one. I've had old laptops with weak USB ports not be able to power it adequately.
Xero-Limit is offline   Reply With Quote
ECUTEK Cable w/Dongle OBDII no license MooKz Engine, Exhaust, Bolt-Ons 3 01-26-2017 05:01 PM
ECUTEK Cable w/ Dongle OBDII no license MooKz NY / NJ / CT / PA 0 01-18-2017 10:07 AM
FS: EcuTek OBDII Dongle mitim3 Audio/Visual, Electronics, Infotainment, NAV 10 12-01-2016 12:31 PM
*SOLD* Mini VCI OBDII cable for Toyota Techstream [NorCal] chas3wba0 Audio/Visual, Electronics, Infotainment, NAV 1 09-03-2014 02:54 PM
Reading OBDII and CANBUS over OBDII-Bluetooth adapter? wparsons Electronics | Audio | NAV | Infotainment 8 06-12-2013 07:17 PM
