#15 |
Vtec Jesus
#16 | |||||||||
Drives: 1996 Integra LS 4DR, 2013 Scion FRS
you're welcome! Quote:
thanks, I will clean it up a bit and add missing pictures and steps when I do some local pulley installs for whoever needs them. try re-editing it and removing everything I wrote ![]() Quote:
| The Following User Says Thank You to Enigmus For This Useful Post: | TouchMyHonda (07-24-2012) |
#17 | |
Drives: Attitude
Issues seen with crank pulleys in Subaru applications typically manifest as misfires or ghost misfires/CELs, usually when used in conjunction with lightweight flywheels. |
| The Following 7 Users Say Thank You to OrbitalEllipses For This Useful Post: | amram (04-02-2014), Anthonytpt (03-31-2013), FearBoy (10-16-2013), Jayde (07-24-2012), KalbiCool88 (01-08-2017), s0sl0w (07-10-2013), Sonolin (02-23-2013) |
#18 |
Wow, compared to my friend's Si that we'll be changing that crank pulley on, this is a breeze! Thanks for the write up!
#19 |
Grand PooBah
Drives: Toyota 86 GT MT
#20 | |
Supra Owner
Drives: 1995 Toyota Supra UK Spec
As for the adding oil to the thread of the crank bolt, also a bad idea.. Adding oil modifies the friction of the threads, meaning you overtorque the bolt (as with the oil you have to tighten the bolt more until the same torque registers on the torque wrench). You should not add oil unless it was stated in the install instructions. Finally, in general, when a bolt is told to be torqued to a certain torque spec, and then turned through another angle, it is generally not good to reuse that bolt. The extra turn usually causes the bolt to undergo plastic deformation - ie. the bolt stretches (as with head studs/bolts), which has usually been done when the pulley was first installed from factory. This will probably not matter either.. I'm sure Perrin would have done their research when they came up with the instructions.
| The Following 3 Users Say Thank You to Snaps For This Useful Post: |
#21 |
NW Region Moderator
Drives: FR-S No More
Added to the DIY Directory:
http://www.ft86club.com/forums/showthread.php?t=7365
| The Following User Says Thank You to DarrenDriven For This Useful Post: | SlammedSilly (12-15-2015) |
#22 |
I Love custom Turbo kits
Drives: Limited BRZ
Perrin's instructions call for oiling it.
| The Following User Says Thank You to Sportsguy83 For This Useful Post: | jdm-az-fuk (07-10-2013) |
#23 | |
Drives: Attitude
#24 | |
Supra Owner
Then we have no problem.
![]() Quote:
I know there are a lot of people on these forums that have very little mechanical knowledge or experience, and so making sure everyone is using correct terminology, and that everything is explained well (as with this DIY), along with giving good information, is important to keep everyone safe...
#25 | |
Drives: 2013 Scion FR-S Firestorm Red MT
I think I tried putting it in 6th on the Si and didn't have any better luck. I do know I ended up with a cat-claw in the flywheel to get it to bust.I can imagine it already, "hey man, want to help me do the crank pulley in THIS car?" "Oh no, not again..." "No, really, it's a lot easier I promise!"
#27 |
Drives: 2013 FRS/01 Tacoma
What i use at work is a chain wrench and you can find them at your local parts store (for any one having problems taking the crank bolt off)
Recommend placing a old belt or rubber hose around the journals of the pulley to protect it from damage. |
#28 | |
Drives: 2013 Scion FR-S MT Raven
| Tags |
| brz, crank pulley, diy, frs, perrin, raceseng |
| Perrin Crank Pulley now available | milenko11 | Engine, Exhaust, Transmission | 96 | 12-10-2017 07:45 PM |
| Crank Pulley and the warranty | Brimford | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 07-08-2012 04:47 PM |
| Perrin Lightweight Crank Pulley for the BRZ/FRS at Redline360 | Redline360 | Engine, Exhaust, Bolt-Ons | 2 | 07-07-2012 11:24 PM |
