#15 | |
Drives: '18 BRZ tS, '18 GTI SE, '11 RS
| The Following User Says Thank You to Elliotw For This Useful Post: | Tristor (03-19-2018) |
#16 |
Drives: 2017 Subaru BRZ Limited
Just a quick update, I ordered a set of Perrin Wing Risers and will be installing them as soon as they arrive. I've received an update that my wheels should be arriving on April 13th (or shortly thereafter), so that gives me a target date for wheels and brakes. I also have packed everything I need (I think) for my first track day in the morning. I'll report back tomorrow night on how it went.
#17 |
Drives: 15 BRZ LTD, 05 FXT
I would like to chime in that no amount of bracing will make up for driveline slop, AND the bushings that address it are even less expensive. Consider doing the rear subframe lockout, and transmission lockout bushings at least to start!
Everything else in this car is tot enough, but those two items see a drastic change without too much NVH.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
| The Following User Says Thank You to JazzleSAURUS For This Useful Post: | Tristor (03-24-2018) |
#18 |
Well, I'd call my first time ever driving on a track a resounding success. Not only did I survive and my car survived, but I even managed to learn a bunch of things. It was a huge amount of fun and the entire group at the track were great people. One gentleman in our group had the foresight to have his wife come along with her camera so she could take pictures of the cars around Turn 5 ("Monaco").
So without further ado here's some pictures: For those wondering, here's the track map for L1 - Short Course which the class I took "Foundations of Road Racing" takes place on. The track is modeled after Fiorano, the Ferrari test track. |
| The Following User Says Thank You to Tristor For This Useful Post: | Racecomp Engineering (04-11-2018) |
#19 | |
* Mishimoto Oil Cooler Kit * Mishimoto Performance Radiator * Mishimoto Radiator Twin-Fan * Mishimoto Radiator Hose Kit * Mishimoto Coolant Overflow Tank * Mishimoto Liquid Chill Premix coolant * Koyorad 1.3 Bar High-Pressure Radiator Cap * Stark Performance Automatic Transmission Cooler * Red Line D6 ATF * Motul 300V 75W90 Gear Oil (for the diff) * Magnetic Drain Plugs for AT and Diff Getting the above at FT86 Speed Factory comes in around $2500, so I think I might be able to budget it in this year if I ditch on getting a second set of lightweight wheels and tires before the summer is out. |
#20 |
Drives: Subaru BRZ
You're overthinking it; just get an oil cooler (preferably 19 rows) and be done with it.
| The Following User Says Thank You to Code Monkey For This Useful Post: | Tristor (03-25-2018) |
#21 | |
Both my coolant temperature and my oil temperature were very high when I stopped in the pit after my last session on track. Given that it only hit mid-80s outside at the track and we expect this summer to be exceptionally hot I'm very concerned about what will happen during track sessions over the summer. The built-in gauge isn't granular enough to be exact, but unless I was misreading it my coolant temperature was around 240F. My math may be a bit off, but I gather that the stock cooling system in a BRZ has a boil-off point around 257F, which means I could potentially expect to have serious trouble at the track if the outside temp is 103F or higher, unfortunately that's a commonplace temp in South Texas during the summer. I can solve for this by increasing system pressure (getting me a boil-off point closer to 265F) and using better coolant, but I also want to get the heat out of the system, which is why I think an upgraded radiator might be worthwhile. I agree that the oil cooler is far higher priority though and maybe if I get it in place it might help take load off the cooling system and bring everything else back in check too. I figure since I have to take the bumper off for the install, I might as well get it all out of the way in one go though. Looks like I could get the oil cooler and the radiator upgrade out of the way in one go. The Jackson Racing Dual Radiator and Oil Cooler kit seems to do both and has fitment to replace the OEM radiator. Does anyone have any experience with this vs running a separated oil cooler and radiator upgrade? Last edited by Tristor; 03-25-2018 at 04:44 AM. |
#22 |
Drives: Subaru BRZ
The coolant and oil temp gauges are on a different scale. Press and hold the middle button on the right of the steering wheel to change the coolant temp display from a dummy gauge to actual temp and you will see that the 270 oil temp mark corresponds to a 230 coolant temp mark. You were probably around 200 F max on the coolant temps.
| The Following User Says Thank You to Code Monkey For This Useful Post: | Tristor (03-26-2018) |
#23 | |
#24 | |
Mishimoto products are generally made to minimum acceptable standards in my experience. The radiator in my forester XT has been replaced due to pin hole leaks, after three radiator caps I tried an OEM one and the issues went away for 1 year, before developing another pin hole leak. Combine that with a poorly aligned overflow fitting on all three, (the line rubbed on the radiator mount no matter what I did.) * Mishimoto Oil Cooler Kit - Not my preference solely based on brand experience, though most have had reasonable experience with this product. This is one part that Mishimoto seems to have down pat. * Mishimoto Performance Radiator - Not needed, unless your coolant temps are going wild...if you do get high coolant temps after your oil cooler, invest in a koyorad! * Mishimoto Radiator Twin-Fan - Not needed, OEM fans flow similar air volume. This is purely an aesthetic move. If you get fans, I recommend SPAL fans, the Mishimoto radiator shroud is fine though. * Mishimoto Radiator Hose Kit - Not needed, once your OEM ones get tired moving to silicone is fine, but there is no major benefit of silicone while your OEM ones are in good shape. * Mishimoto Coolant Overflow Tank - Not needed, OEM is fine. * Mishimoto Liquid Chill Premix coolant - Again, use OEM. * Koyorad 1.3 Bar High-Pressure Radiator Cap - Good part, but it comes free if you need it and get the Koyorad radiator! * Stark Performance Automatic Transmission Cooler - Important, definitely a good call. * Red Line D6 ATF - Motul ATF is another good option, but the Red Line product is great as well. * Motul 300V 75W90 Gear Oil (for the diff) - You're looking for Motul Gear 300, 75W90. NOT 300v, (that's engine oil,) and NOT 300V 75W90LS, that's for clutch type LSD's, though it should work fine in the Torsen style as well. * Magnetic Drain Plugs for AT and Diff - Diff already has one, AT is not really necessary. My opinion is a lot of the components you're asking about aren't an upgrade. Consider the R&D budget of a value oriented performance parts company that focus on customer service as their key differentiation as opposed to a lifetime part. (It's a lifetime warranty, NOT a lifetime component.) versus the budget of Subaru, Toyota, or a high-end cooling company that's been doing it for decades with nearly no marketing. Just my opinion and experience, regardless of what you choose to get I hope the components serves you well and is a great experience for you and your 86! The red/yellow/green coloring should make sense, I've interjected with my experience and opinions.
| The Following User Says Thank You to JazzleSAURUS For This Useful Post: | Tristor (03-26-2018) |
#25 | |
#26 | |
Glad you checked your data!
| The Following User Says Thank You to JazzleSAURUS For This Useful Post: | Tristor (03-27-2018) |
#27 |
Drives: 2015 BRZ Limited
I'm considering the JR dual Rad/Oil cooler myself.. lots of great things about it in this thread: http://www.ft86club.com/forums/showthread.php?t=104943
| The Following User Says Thank You to JeremyR For This Useful Post: | Tristor (03-27-2018) |
#28 |
Drives: '17 86
Nice build.
You're right about some great roads around there. The Twisted Sisters are a blast. Is that track up around San Marcos? |
| The Following User Says Thank You to nitro_alltrac For This Useful Post: | Tristor (03-28-2018) |
| 48 States cross-country road trip | jababa82 | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 07-09-2017 02:23 PM |
| Subaru differential specialist? | kster1 | Northern California | 5 | 12-11-2014 01:11 PM |
| It's Official: Road conditions in L.A. region judged worst in country | danthedirt | Southern California | 4 | 10-04-2013 11:58 PM |
| 86Drift, Australian 86/BRZ Specialist | 86drift | Australia Classifieds | 73 | 04-14-2013 03:22 AM |
| FR-S Cross Country Road Trip! | anusornsan | Scion FR-S / Toyota 86 GT86 General Forum | 13 | 09-11-2012 06:01 AM |
