#15 |
Drives: 2017 BRZ
I know there’s a few 2017s who went with a supercharger kit that replaced the red manifold. Maybe they can chime in. If not, when I put on my Edelbrock kit, I can snap some photos
| The Following 2 Users Say Thank You to Barefootdan For This Useful Post: | Teseo (01-26-2018), Williampreza (01-26-2018) |
#16 |
Drives: 2014 Subaru Forester
| The Following 4 Users Say Thank You to tehShirt For This Useful Post: |
#17 |
Drives: frs
And the other? Where bolt it on the block?
Edit: member found the pic. I would like to try some porting/smoothing the inside Last edited by Teseo; 01-28-2018 at 04:18 PM. |
#18 | |
Road-hole
Drives: 2013 Whiteout FR-S
it's pretty easy actually...
if the average is higher, it's probably netting gains. Is it proof? no, but it is an indicator. Jaden |
#19 | |
Drives: 2017 Ice Silver BRZ Limited
![]() Much appreciation. |
#20 |
ZWEI KOLBEN
Drives: 2017 86 Halo 6MT
It's not common practice to polish anymore is it? Port would mean removing the casting marks & in the old days "matching" the ports. but I thought a shiny finish was now considered bad.
#22 | |
So, the smoother the path for the air to follow, the better. Whether it is a substantial enough improvement to warrant several hundred dollars investment is yet to be seen. |
| The Following User Says Thank You to Williampreza For This Useful Post: | humfrz (01-30-2018) |
#24 |
Drives: 2017 Toyota 86
Honestly I thought with the tolerances now a days that one would not need to port and polish unless it was a rebuild or high end build. That was my understanding of why it was not done as often as it use to be. Plus we switched from leases to unleaded gas.
#25 | |
![]() humfrz |
#26 |
Pics Inside the 2017 Red Manifold?
In response to my own question, I bought a gasket (just in case, turned out I didn’t need it) and pulled the throttle off. Here is what I found:
The plenum behind the throttle body actually looks okay ![]() But then a peak down the runners reveals a rough ride. The surface is like a very rough sandpaper (no surprise there, sandcasting and all), ![]() Here’s a detail/close-up shot of a runner wall. ![]() It seems to my untrained eye that this manifold is a good candidate for a port/hone. Whether Extrude Hone is the way to go or not, I’m not sure. I haven’t seen any brush style hones that look flexible or long enough to deal with the length and curvature of these runners. Either way, hope this information proves useful! Sent from my iPhone using Tapatalk |
#27 |
#28 |
ZWEI KOLBEN
My understanding is this.
A rough, sandblasted surface, leaves tiny little holes for air to reside. Air slides better on air than a shiny smooth surface. I know it sounds crazy but on a large scale think of a truck bed. Tailgate down air is flowing over the cab and into the bed. The now horizontal tailgate is now NOT acting as a parachute. Efficient right? Actually no. The tailgate up traps a rolling air bubble in the bed. air coming over the cab simply bounces of this rolling air mass. Makes sense even it is seems less than logical -at first. IIRC people would match the ports, get rid of casting marks and make the surface as straight and smooth as possible....then rough it up with a sandblaster. |
| The Following User Says Thank You to SCQTT For This Useful Post: | sroby (09-14-2019) |
| 2017 Red Manifold | BrunoCr7 | Engine, Exhaust, Transmission | 121 | 03-26-2018 01:35 PM |
| 2017 intake manifold | oldgunfan | Engine, Exhaust, Transmission | 27 | 02-15-2017 04:48 PM |
| 2013 intake manifold vs 2017 Aluminium intake manifold | Bobster | Engine, Exhaust, Transmission | 29 | 12-19-2016 10:40 AM |
| 2017 Aluminum Manifold F/I | Gearbanger | Forced Induction | 11 | 11-14-2016 05:56 PM |
| PTuning Spec RS *pics inside* | Dragonitti | Other Vehicles & General Automotive Discussions | 121 | 11-19-2011 11:52 PM |
