Old 01-22-2018, 10:06 AM   #15
dattran86
Driver
Drives: 2013 Whiteout FRS
Originally Posted by TommyW View Post
Lowering will automatically reduce camber. Since no tracking you should be fine with that
I though lowering a car will increase negative camber...especially the rear
Check out my website:
http://www.aim4apex.com/
IG: aimforapex
dattran86 is offline   Reply With Quote
The Following 2 Users Say Thank You to dattran86 For This Useful Post:
Lust (01-23-2018), wparsons (01-24-2018)
Old 01-22-2018, 01:00 PM   #16
churchx
churchx's Avatar
Drives: 2014 GT86
Lowering will naturally gain some camber on ours, indeed. IIRC with reasonable lowering within inch with two camberbolts front i've heard about -2.5 max camber front, while at stock height it's about around -2.25 +/-.
Worth not overdo lowering/dropping though, as aside from reducing practicality/comfort/daily driving compliance one will need to spend much more to fix illeffects introduced by overlowering (mostly if dropping more then 1"), like need to get diff riser, parts to correct rollcenter changes and so on, it's not just about getting cheap china/taiwan coilovers and dropping to ground max they can go, so that ride becomes unbearable, handling awful and so that one can leave paint and plastic bits on speedbumps and steep driveways.
In general, for only daily driven car i'd keep stock height (already not too high) as is.
The Following User Says Thank You to churchx For This Useful Post:
Old 01-22-2018, 01:00 PM   #17
cjd
cjd's Avatar
Drives: 2017 BRZ
Well, technically more negative camber and "reduce" are the same, though positive camber is almost never a thing so "reduce" might also be understood to mean "less negative camber"...
That said... lowering increases negative camber.
For the OP: Unless you're into a drift setup, I'd stay at -1.5° to -2° camber in the back. Front, for a good balance of wear/performance, over 2° up to -2.5° or as close as you can get. If your mix of spirited driving is reasonable, you won't be wearing tires faster than they age out unless you're on something in the one-lap-wonder category (e.g. RE71-R...)
The Following User Says Thank You to cjd For This Useful Post:
dattran86 (01-22-2018)
Old 01-22-2018, 01:22 PM   #18
TommyW
TommyW's Avatar
Drives: '13 Whiteout
Same thing. Increasing negative camberor reducing camber
Old 01-22-2018, 01:24 PM   #19
dattran86
Driver
my misunderstanding,
usually I dont considered positive camber, so when you said reduce. you actually meant reduce the value from positive to negative.
IG: aimforapex
Old 01-22-2018, 01:57 PM   #20
jamal
jamal's Avatar
Drives: Legacy GT
The front end gains much less negative camber with bump travel than the rear. The result is that there's not enough up front and too much in the back. That's pretty much true for the stock settings at stock height, and then only gets worse with lowering. Why? It's safer, as it results in more understeer at the limit, and minimizes tire wear.
So anyway, if you're trying to maximize overall grip and improve the balance you'll want more negative camber up front than in the rear. Otherwise all those fancy suspension parts are kind of going to waste.
Not sure what camber bolts you have on the way but those STs should have some slotting at the front so you can add some negative camber without extra parts, or with just a second set of oem lower bolts.
jamal is offline   Reply With Quote
Old 01-23-2018, 05:56 AM   #21
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Originally Posted by churchx View Post
guybo: it's not "more weight" balance to the front with camber changes.
It's changing "grip" bias/balance. Adding more camber to one end, eg. front, adds grip to that end in curves, as due leaning on outside tire during turn static negative camber compensates tire sidewall flex and you get more even/better contact with that outside tire during turn, making that end less tending to loose traction. Reducing camber makes that contact patch worse during turn, reducing grip on that end.
That aside your camber settings do exactly that, with more camber (versus stock almost zero camber) in front.
Also increasing rear camber will not make car more tail happy, rather opposite, as now you are adding more grip mid turns to rear. Though due little change from -1.7 to -2, not by much.
Toe in adds stability and with to self-center to end too (and toe-out increases tendency to loose traction, to steer that end out) where it's dialed in. It impacts more tire wear and fuel economy though, so imho best would be to get wished balance by camber, thus zero toe front (if it's even, and camber is not at too high, imho not too much of lane wandering), and slight toe-in rear, like you have.
I said that I have done a lot of deletes and have shifted the balance of the weight of the car forward.
Old 01-23-2018, 08:00 PM   #22
Lust
Drives: 2017 Subaru BRZ
If it were me, I’d go with -2 camber up front with 0 toe and -1.5 camber in the rear with 1/32” - 1/16” toe in. Like what other people are saying, toe can kill tires if not setup properly. These settings are a good starting point for what you’re describing. On McPherson strut cars, the front wheels gain very little camber as load increases which is why you want more static camber up front. You can also increase caster to reduce static camber but it can be disadvantageous if you have too much caster. A good article can be found on the motoiq website where they go into some detail about setting up your suspension.
Lust is offline   Reply With Quote
The Following User Says Thank You to Lust For This Useful Post:
guybo (01-24-2018)
Old 01-24-2018, 02:20 AM   #23
cyin86x
Drives: Rocket Bunny V3
i personally wouldnt go more than -2 degrees. Tire wear starts to become an issue once you go any more than that.
cyin86x is offline   Reply With Quote
Old 01-24-2018, 10:24 AM   #24
Dee
Drives: 2014 Asphalt FRS
If I am wanting 1.5* front camber will I need camber bolts?
Dee is offline   Reply With Quote
Old 01-24-2018, 10:28 AM   #25
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
I did.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 01-24-2018, 10:32 AM   #26
Dee
Originally Posted by 8RZ View Post
I did.
Are you on ST coils?
Old 01-24-2018, 10:37 AM   #27
8RZ
The Gunshine State
8RZ's Avatar
Megan.
Current DD: M235i
Old 01-24-2018, 10:43 AM   #28
Dee
Megan.
Oh, well I’m curious if I need them because the STs have slotted struts
t86rs rear suspension. stock but 2.6 degree neg camber??? Crunk81us Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 10-18-2016 04:55 PM
Chamfer degree of Hub RMP Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 04-03-2015 01:21 AM
Rear Toe degree? Pacific Auto Tracking / Autocross / HPDE / Drifting 3 09-30-2013 10:48 PM
San Francisco sunset shoot - another shoot with another set of wheels WheelDude.com FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 19 05-03-2013 05:00 PM
San Francisco sunset shoot - another shoot with another set of wheels WheelDude.com BRZ Photos, Videos, Wallpapers, Gallery Forum 3 04-12-2013 02:35 PM
