Old 01-19-2018, 10:49 PM   #15
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Best $500 I spent on accessories/parts for my car was on the OFT. No contest. I purchased mine when Vishnu first release this product. I suppose you can get a tactrix for less and do almost the same thing, but you wont have real time sensor readouts. I'll likely end up getting one of those as well just for data logging. (more channels and better resolution on logs)
Intent > Content
The Following User Says Thank You to solidONE For This Useful Post:
Vin (01-20-2018)
Old 01-20-2018, 04:26 AM   #16
Kodename47
Kodename47's Avatar
Drives: UK GT86
Originally Posted by S. Snake View Post
When I get my FI kit I'm going to use the Ecutek to load my CARB tune while continuing to use my OFT occasionaly to monitor stuff like AFRs and oil temps.
Why not sell the OFT and buy the EcuTek BT-EVI? Better logging, better displays that you can customize and possibly even control over your maps if the tuner adds it in. You can't guarantee the OFT for logging/display will work due to the reliance of using certain ROM IDs in the OTS maps.
.: Stealth 86 :.
Kodename 47 DJ:
The Following 2 Users Say Thank You to Kodename47 For This Useful Post:
Luftwaffel (01-20-2018), S. Snake (01-20-2018)
Old 01-20-2018, 08:33 AM   #17
Luftwaffel
Boost Creep
Luftwaffel's Avatar
Drives: 2016 HyperBlue BRZ
Basically the long and short of OFT is, it's only better if you don't want a real protune on a dyno. It makes a lot more sense and it's a fair bit cheaper for that kind of person since it offers Stage 1/2 and E85 OTS maps. Nobody will dyno tune you on OFT.
There's also the Android and Torque option for monitoring. I wanted an OEM look so this is where I view most of my vitals.
SBD400X Turbocharged 2016 Series.HyperBlue BRZ
Luftwaffel is offline   Reply With Quote
Old 01-20-2018, 04:02 PM   #18
S. Snake
S. Snake's Avatar
Drives: 13' Asphalt
It was a gift from my wife and I dont like to sell gifts. I also already have a cable run and a custom mount for the OFT in my car for when I actually want to use it as a gauge pack. Thanks for the heads up about the ecutek Bluetooth thing, haven't even looked into it but now it's on my radar.
Sent from my SM-G930V using Tapatalk
"always forward" >>>>>>>>>>>
S. Snake is offline   Reply With Quote
Old 01-20-2018, 10:54 PM   #19
Submarinesonce
Drives: Frs
my FRS ran 14.3 @ 97 (DA corrected) on a OFT e85 tune and a CNT (budget) uel header... still had the spare tire/tools and a toddler seat in the car half a tank of gas and normal street pressure in the tires... less than a thousand dollars worth of mods/ minor effort and the car is significantly quicker than it was in stock form. Thats why OFT is so popular.
JDL UEL Turbo GT2860RS, AP Racing BBK, Verus Splitter/diffuser/canards, Sard rep carbon wing, TFF bash bar, HKS hi power, Tein Flex A, Hotchkiss FSB, Radium MCB, Konig Hypergram 17x8, FS Indy 500, 6k HID, Whiteline trans bushing insert, Verus AOS, grimmspeed strut brace, Racerx oil cooler w/ setrab 619, ES steering rack bushings, Whiteline subframe bushings, Toms tails, STi mirror caps, IRP shifter, TRD Steering wheel
Submarinesonce is offline   Reply With Quote
Old 01-21-2018, 02:23 PM   #20
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Also the OFT is flexible. I can flash a number of different tunes or go back to the stock tune and it only takes 10 minutes. It's easy as you want it to be with OTS tunes, or you can mess with Romrqaider and make it as complex as you like and do your own tune, or get a custom OTS tune from someone like Wayno or a custom E-Tune from Shiv himself.
I have no experience with Ecutek so I don't know what it can and can't do.
Old 01-22-2018, 04:05 PM   #21
solidONE
solidONE's Avatar
What does a stock one do? 14.3 @ 97 is not super slow but it doesnt sound too fast at all. lol
Intent > Content
Old 01-23-2018, 07:37 PM   #22
S. Snake
S. Snake's Avatar
Drives: 13' Asphalt
Id wager a stocker would do mid to high 15s if not low 16s in the 1/4 depending on elevation, driver, tire wear etc.
Old 01-23-2018, 09:28 PM   #23
steve99
From a magazine review in Australia
Performance Statistics Subaru BRZ
0-60 km/h 0-100 km/h 0-400 m Top speed
3.7 8.2 15.8 144
Performance Statistics Toyota 86
3.6 8.1 15.7 144
Old 01-23-2018, 11:48 PM   #24
solidONE
solidONE's Avatar
I guess 14.3 @ 97 is a pretty decent improvement. As fast as this supercharged one.
Stock MY13 14.8 @ 93.6
Supercharged with 224 WHP 14.3 @ 98.5
https://www.edmunds.com/car-reviews/...ck-tested.html
Intent > Content
Old 01-24-2018, 12:44 AM   #25
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
ACtually that's only half true...
Running techstream or ecuedit with tactrix and you can have real time sensor readout...
Only problem with techstream is that for instance, I get a 4 psi map sensor reading at idle N/A because I have an omni 3 bar and afaik you can't rescale the sensor in techstream...
Jaden
Jaden is offline   Reply With Quote
Old 01-24-2018, 03:00 AM   #26
solidONE
solidONE's Avatar
Jaden
Can you run either of those apps on a tablet or phone to display sensor data like gauges, or do you have to use laptop computer?
One function I found useful is being able to log while sensor data is visible. Can you do this somehow using tactrix with whats available?
Intent > Content
Old 01-24-2018, 03:32 AM   #27
Jaden
Road-hole
you can with ecuedit I believe...
I think you can with ECU edit. Both the viewing on the tablet and logging while viewing sensor data. Also, Ecuedit allows for logging and viewing of third party wide bands.
Jaden
Old 01-25-2018, 03:54 AM   #28
solidONE
solidONE's Avatar
Jaden
That would be an almost ideal setup.. tablet that does all the things the OFT does with more channels, better resolution (in logs and on screen), simultaneous sensor data display/logging, AND tweak your tune on the same device that's open source.
Intent > Content
