Old 12-06-2017, 05:51 PM   #15
Detroiter
Detroiter's Avatar
Drives: 2014 Scion FR-S Monogram
Originally Posted by guybo View Post
3" catback on a NA 2.0L car? That will kill torque right there. Now that I reread the OP, Deleting the FP cat without a tune may have killed some power. Still, it's odd to me that it performed so much worse.
As for the CEL P0420, the reason it's bad is that the car may not run some self diagnostics when it sees a CEL. You can in theory have hidden issues come up but the ECU isn't running those tests. I'm not sure exactly what tests that'd be but there are techs familiar with techstream in this forum who might know
There have been dyno charts showing no change or even a slight gain with my 3.0in catback just like any other catback on our cars. It does nothing but change the noise. As for the catless FP I can guarantee it has little to no effect on power and torque untuned. I was stating that there is no NEED to get a tune with even a full exhaust system on our cars. Yes it will get you the power and make it run better but there is nothing damaging being done let alone causing it to run that lean.
Raven
OFT Stage 2 UEL E85 | Tomei UEL Headers | Catless FP | Greddy Revolution RS Catback | HKS Air Filter | Toyota Badge Swap
Detroiter is offline   Reply With Quote
Old 12-06-2017, 06:04 PM   #16
steve99
you will only get the P0420 CEL if you change to cattless header.
Car will light CEL and cruise control is disabled. Other than that noting bad will happen. Having the constant CEL does mask other issues though.
disabling P0420 code in tune just stops the CEL for that particular code and it stops ECU taking action on that code ie disabling cruise control.
however disabling p0420 code will not make the ecu pass the readiness checks it just disables CEl for that code. Readyness checks require data from front and rear 02 sensors, and the ecu wants to see certain patterns in the data from the sensors before. with no cat you will generally fail readiness checks for cat converter and emissions.
no current tune software forces readness check pass
Old 12-08-2017, 03:00 PM   #17
Joeyb860
Joeyb860's Avatar
Drives: 2017 860 SPRINTEK
So I have uel cat less headers and cat less front pipe with stage 2 + oft tune but did not change my intake do I need to do anything to the mas sensor? Would I get any more if I change to a trd cold air intake? I was not going to change it because when the 36,000 mile warranty is up I was going to turbo it so didn't want to waste the money on cold air intake. Im going to e 85 this weekend and have seen threads about scaling the maf sensor before going to e 85 any in put on this topic. Thanks.
Joeyb860 is offline   Reply With Quote
Old 12-11-2017, 03:01 AM   #18
NRXRaptor
I'd just email Shiv on the OFT website. I had questions about my setup and he answered them. He'd know better than anyone on here
NRXRaptor is offline   Reply With Quote
The Following User Says Thank You to NRXRaptor For This Useful Post:
Joeyb860 (12-11-2017)
Basic Bolt on mods intake, exhaust tuning guide steve99 Engine, Exhaust, Transmission 204 09-12-2022 08:06 PM
Interesting Findings on the Dyno - OpenFlash/Vishnu tuned ck-GT86 Software Tuning 136 05-15-2019 06:21 PM
Interesting Findings after ProECU Tuning! vagthomas Software Tuning 11 12-06-2017 03:24 PM
FS/FT - SC: 2015 Scion FR-S with interesting mods - $16,5k RWDfun Cars for Sale/Trade 6 03-14-2016 12:41 AM
Interesting Findings about BRZ Audio Output Chad_W Electronics | Audio | NAV | Infotainment 14 05-03-2013 08:28 PM
