Old 12-02-2017, 03:54 AM   #15
Originally Posted by carsebuco View Post
Thanks. Sometimes a different lingo is necessary for me to finally get it. You hit the nail for me on this one.
Now, going off on what the guy said above, should I tell them I expect the same numbers on both sides next time?
You will never get exactly the same numbers on both sides. If you do then it is coincidence or they are bullshiting you. As long as things are withing the specs you are good to go.
carsebuco (12-02-2017)
Old 12-02-2017, 06:01 PM   #16
Lust
Drives: 2017 Subaru BRZ
I’d take the car to a performance alignment shop or someone that will take their time to get the alignment dialed in. Usually you’d want 0 toe up front and around 1-2 degrees negative camber in the front. Having heavy, aggressive offset wheels can also make the car feel less precise
Lust is offline   Reply With Quote
The Following 2 Users Say Thank You to Lust For This Useful Post:
Racecomp Engineering (12-04-2017), wparsons (12-04-2017)
Old 12-04-2017, 06:49 PM   #17
That alignment isn't great, but it's about what I'd expect from the factory at least. A set of the OEM camber/crash bolts would help tremendously.
How many miles on your new tires?
- Andrew
understeer on 17 brz alex.s Suspension | Chassis | Brakes -- Sponsored by 949 Racing 37 09-11-2017 05:05 AM
Not understeer, not oversteer... something else? Mazikowski Tracking / Autocross / HPDE / Drifting 15 07-25-2016 10:24 PM
Do pigs understeer? Thrustin Off-Topic Lounge [WARNING: NO POLITICS] 11 05-31-2014 10:42 AM
BRZ stock suspension understeer... what to do? mtimney Tracking / Autocross / HPDE / Drifting 40 07-31-2013 01:48 PM
03/23 Reviews --> No understeer complaints... bloomy116 BRZ First-Gen (2012+) — General Topics 19 03-26-2012 12:06 PM
