Old 11-21-2017, 01:07 AM   #15
humfrz
Ah, well. It'll be better tomorrow. So will the taco bus.
Yep, at least that cute little senorita was still at the taco bus ......
And my granddaughters are getting well trained to protect me in my old age ....
humfrz
Old 11-21-2017, 12:42 PM   #16
RallySTI
Drives: 2013 Subaru BRZ
Originally Posted by Rezi View Post
Hmmm, interesting.
The only heatshield that i'll have is the oem frontpipe and it looks pretty rusty to me when looking down from the engine bay.
Shouldnt it create that noise even in neutral?
Anyway i will change the TOB, new clutch disc, new pressure plate and an lw flywheel next month. Gonna investigate the heatshield and tap it a little to see if it is loose somehow.
The noise seems to be related from harmonics since its only occurring at certain RPM and load ranges. This could be causing a heat shield, unloaded gears in gear box or something else (bolted to the subframes or driveline) to make the noise you are hearing.
FYI...If you plan to install a LW flywheel then this will most likely increase the presence of any harmonic noise coming from the drivetrain. So your annoying noise may become more annoying, stay the same or may entirely go away(self correcting automotive repair SCAR ) SCARs are my favorite !!
RallySTI is offline   Reply With Quote
The Following User Says Thank You to RallySTI For This Useful Post:
Ultramaroon (11-21-2017)
Sequential gear changes, without changing the gearbox 86 South Africa Engine, Exhaust, Transmission 15 11-08-2017 08:41 PM
Loud Hum/Grinding Noise + Vibration in 5-15mph gear range, in gear and rolling neutrl jakebrz Issues | Warranty | Recalls / TSB 14 06-06-2016 07:28 PM
Gearbox noise normal? Anuist Issues | Warranty | Recalls / TSB 5 09-08-2015 10:49 PM
Swap out OEM clutch, OEM synchros/gearbox brzadmir Engine, Exhaust, Transmission 19 05-04-2013 04:13 PM
Clutch / Diff / Gearbox issue? doggy Issues | Warranty | Recalls / TSB 5 10-03-2012 11:47 AM
