#15 |
117K miles, build date 2/2012, delivery Early May 2012.
Nothing I consider a real issue. Like @Tcoat mine is all original, including plugs, etc. (with the exception of fluids and tires). Well, I did have the fuel pump replaced under warranty just because I could (the cricket issue). Not really sure I had crickets. I do have weepy tail lights and I most likely need brake pads (light just came on this AM for about 10 seconds). The tail lights would be fixed by a new gasket I haven't installed yet, as I need to dry them out first. Looking forward to at least another 150K miles out of it.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
| The Following 5 Users Say Thank You to Dadhawk For This Useful Post: | Darth Khan (11-17-2017), Tcoat (11-17-2017), TorontoNat (11-17-2017), Vides990 (11-18-2017), Votlon (11-17-2017) |
#16 |
Drives: 13 BRZ (sold) 20 BRZ TS (sold)
At roughly ~115k miles now. Did upgraded clutch at ~100k and now doing rotors/pads for the first time (upgrading those too), leaky boot on the differential so that's getting done, and finally needed a new battery. Other then that just been oil changes/wipers/tires/fluids as needed, these are reliable cars if you take care of them, no doubt.
| The Following 3 Users Say Thank You to Vides990 For This Useful Post: |
#17 |
Reformed
Drives: '23 GRC, '11 Prius, '04 RAV4
https://www.consumerreports.org/car-...reliable-cars/
![]() as long as the car drives fine and the gearbox feels good don't think there is much to worry about besides maintenance items.. |
#18 | ||
Undisputed El Presidente
Drives: Zenki 37J ZN6
^that's what I meant. I do not have rod knock but do have detonation at times but only under hard conditions. I monitor it and usually mixing in some 100 Oct fixes the problem (I'm in CA so this gets me to 93 Oct vs. the crappy 91 I got) Quote:
I don't know about the coil packs. I haven't loss one yet but now that I am tracking I am tossing it in with the wear items. Heat kills them from what I have seen. I don't really have a ton of oil issues. My timing cover has been leaking for a while, but not bad enough to get it fixed. And the blowby is enough to measure in the catch can but not enough to see a loss between changes (I usually change my oil between 5k and 10k depending on what kind of driving I've been doing) I do know a few other local owners who experience faint rod knock on cold start and they are around 60-70k miles on the car. Not sure how fast it is progressing for them though. Both of them track occasionally as well, like 3-4 times a year. |
#19 |
Drives: 2014 Subaru BRZ Limited 6MT SSM
Thanks for the repiles guys. I'm hoping this discussion is helpful to OP.
I think my issue is more of a piston slap issue. The "knocking noise" is only present on really cold startups and has just started with the cold weather coming in. Non-existent when the car is warmed up. I'm going to try to get a video |
#20 | |
Yeah sounds like rod knock. Dang that sucks. It will eventually get worse and then one day you will be winding it to redline and end up with constant knock when not under load. At that point the damage could be more than a simply bearing replacement. I’ve been there done that on a few cars. You hear it at cold start and think, “I really need to tear this thing down and replace the bearing(s)” ... “Nah, not in the mood for such a big job, I will do it in the winter” next think you know it totally spins a bearing and now you are potentially replacing a rod or crank. I did price out the rods and crank and they are reasonably priced. So that’s exciting. |
#21 |
Wes
My 2017 makes a light knocking noise on warm up since it got colder here too. Didn't think anything of it. It's not there when I drive off. Should I be worried?
#22 |
No. Cars make weird noise until they warm up. It doesn't mean they are being harmed. Just don't go hot-rodding until it reaches operating temperatures.
| The Following User Says Thank You to Tcoat For This Useful Post: | StraightOuttaCanadaEh (11-17-2017) |
#23 | |
Cold engine can knock it does not automatically lead to blowing them up.
| The Following User Says Thank You to Tcoat For This Useful Post: | toeout (11-18-2017) |
#24 | |
You should NEVER have rod knock. Not even cold. Sure there are different noises on a cold start but it should NOT be rod knock. What he is hearing may not be rod knock. But the early stages of a rod bearing going will be herd on cold start. |
#25 |
Just saying it is a little early to assume it is rod knock at all.
#26 | |
True, but I definitely wouldn’t write it off and ignore it. That is all I was getting at. Something cheap to fix ($26 rod bearing) can turn into catastrophic failure (rod, crank or maybe block). Lots of labor though. |
#27 |
Drives: 2013 FR-S Series 10
Curious as to how the suspensions hold up on these cars. Hopefully not like a lot of BMWs where the bushings are shot after 60K.
#28 |
Drives: 2014 BRZ Limited
| Buddy Club Race Spec Coilover Problems on Problems on Problems | mpross | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 48 | 09-05-2016 12:18 AM |
| rom tuning for improved gas milage | ganz954 | Software Tuning | 19 | 12-02-2014 11:08 AM |
| Does Turbo effect gas milage?? | beesmiff07 | Forced Induction | 86 | 10-30-2014 11:25 PM |
| WTB: FRS/BRZ high milage | cools20 | Cars for Sale/Trade | 0 | 10-13-2014 02:10 AM |
| Milage App. | execoll | Scion FR-S / Toyota 86 GT86 General Forum | 11 | 09-14-2012 01:23 PM |
