Old 11-19-2017, 01:39 AM   #15
Dogster70
Dogster70's Avatar
Drives: 2013 Scion Frs Whiteout
Originally Posted by tyler_win_photo View Post
Yes that will fit in the front for sure. The rear will fit, but will rub occasionally with a 255 or 265 depending on how low you go and how much camber you plan on running.
Before you do anything else, I recommend you do more research on the topic. For example when you install the b16's and lower your car, the camber in the rear is going to be way off... which in turn you'll have to buy lower control arms because stock the rear has no camber adjustment.
Ah so im currently waiting on the b14s to come in so you think it would be smart to order the control arms now then as well? before buying the rims?
Dogster70 is offline   Reply With Quote
Old 11-19-2017, 01:40 AM   #16
Dogster70
Dogster70's Avatar
also im not trying to go much lower than stock height maybe about a half inch to an inch lower.,
body kit, fender flares, rims, size, wheels
Fender flare identification. swarb Cosmetic Modification (Interior/Exterior/Lighting) 2 04-10-2017 07:32 AM
I cant figure it out... Need help snapplepat Forced Induction 9 02-20-2017 10:22 AM
Rocketbunny flare Install - Rivet Nuts ? Iamwu Cosmetic Modification (Interior/Exterior/Lighting) 7 07-18-2016 01:16 PM
FS> VALENTI front Toyota emblem ornament plate (flare red) k1s3k1 Australia Classifieds 0 06-06-2014 08:23 PM
BRZ rear diffuser + flare caps omgwtfbbqsauce AUSTRALIA 6 10-16-2012 04:34 AM
