#15 |
Only users lose drugs.
Drives: All the time
Oil doesn't go bad - it's born that way.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
| The Following 2 Users Say Thank You to venturaII For This Useful Post: | Tcoat (09-25-2017), Ultramaroon (09-26-2017) |
#16 |
[ame="https://www.youtube.com/watch?v=wV1FrqwZyKw"]Lady Gaga - Born This Way - YouTube[/ame]
| The Following User Says Thank You to Tcoat For This Useful Post: | venturaII (09-25-2017) |
#17 |
If I remember correctly in the owners manual it states that there is both a mileage and time limit for oil changes. In the early models I think it was 7500 or 6 months and was reduced to 6000 or 6 months later on. While the car is still under warranty I'd follow the 6 month guideline just in case...
| The Following User Says Thank You to gravitylover For This Useful Post: | Tcoat (09-25-2017) |
#18 |
| The Following User Says Thank You to venturaII For This Useful Post: | Tcoat (09-25-2017) |
#19 |
Honarary Member
Drives: 2015 FRS
Same situation as you OP, my home and work is only around 7~ miles apart.
But I still change it every 7 months, just to be safe. I have a 2015 and barely putting 12k miles on it... almost 3 years later...
#20 |
Drives: 2017 manual BRZ
I don't see how time effects oil let alone a full synthetic. Mileage ofc but not time. If I did an oil change then left my car for 6 months without ever starting it I'm not going to change it again. That's absurd. Even though the manual states that I should waste that oil.
Sent from my Pixel XL using Tapatalk |
#21 |
Drives: car
@Somerandom18 What I've heard is that moisture collects in the oil. If the car isn't driven often enough or at optimal temperature, then that moisture doesn't get boiled off out of the oil. You've probably heard about people finding sludge under the oil cap when they don't drive their car enough.
#22 | |
#23 | |
Not a troll
| The Following User Says Thank You to Cole For This Useful Post: | Ultramaroon (09-27-2017) |
