Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
09-22-2017, 12:14 AM | #15 |
Drives: 2017
Are you guys going to be testing more wheels? I'd personally like to see some Enkei wheels tested, preferably 18x9.5 in any of the wheels they make for our cars.
09-22-2017, 09:22 AM | #16 | |
32mm on all pistons according to our digital caliper. Pistons are not tapered.
Otherwise, we've added the DBA rotors we sell on our Subispeed side for STI application as well as STI application pads to complete the kit. OE lines can be used on these calipers, so any SS line that is offered for the twins should work as well. Any aftermarket SS line kit currently available should work. Yes, once time permits! |
The Following 3 Users Say Thank You to FT-86 SpeedFactory For This Useful Post: |
09-22-2017, 10:59 AM | #17 |
Drives: Subaru BRZ
So the pad shape for the front is FMSI D1001 / D1016 / D1050. What is the FMSI for the rear?
09-22-2017, 01:19 PM | #18 | |
Drives: Legacy GT
Probably 961.
Did you take off the boots and measure the piston where it sits in the bore, or just the face of it? Pistons look like this usually Last edited by jamal; 09-22-2017 at 02:26 PM. |
09-22-2017, 09:56 PM | #19 |
Drives: 2017 Subaru BRZ limited PP
Any chance you'll try the te37v sl 17x9 +36 / 17x9.5 +40 for clearance? Really interested in picking up a set from you guys. Thanks!
The Following User Says Thank You to ryann.mendoza For This Useful Post: | cjd (09-28-2017) |
09-28-2017, 01:16 AM | #20 | |
Killed Scion
Drives: 2013 FR-S Whiteout
Miyuki みゆき "Beautiful Snow" The Whiteout FR-S Instagram: trevor.parque |
09-28-2017, 01:56 AM | #21 |
Drives: between cars...
Well... you can put the RPF1s 17x9 +35 on the no fly list. It took 8mm worth of spacers to get this clearance (and poke). Learn from my mistake.
The Following User Says Thank You to imnotsureaboutbrz For This Useful Post: | orz (10-30-2017) |
09-28-2017, 05:02 PM | #22 |
The Following User Says Thank You to FT-86 SpeedFactory For This Useful Post: | ryann.mendoza (09-28-2017) |
10-03-2017, 01:27 AM | #23 |
Drives: 2017 WRB BRZ Limited PP 6MT
Hello!
Man, the combination of the PP Brembos plus this bolt pattern make it so hard to find good wheels that fit without spacers... I've been trying to find the right wheels for awhile and I've basically narrowed my search down but may have to go back to the drawing board if this won't work. Would this fit at all? TE37 Saga 17x7.5 +44 Thanks for your time, hope to hear back from you soon! Last edited by Daemonomics; 10-08-2017 at 09:47 PM. |
10-03-2017, 01:36 PM | #24 |
Kouki-Monster
There's a lot of wheels that fit
All Enkei RR wheels in 18" Advan RZII 18x9.5 +45
Rich Anderson
EMPOWER AUTO |
10-04-2017, 10:44 AM | #25 |
Drives: 2017 BRZ series yellow
What is the weight on the GRAM LIGHTS 57DR WHEELS 17X9 +38MM? Also were guys able to fit any other wheel options for the 2017 BRZ w/ performance package?
The Following User Says Thank You to TRBO FRK For This Useful Post: | Tristor (02-28-2018) |
10-04-2017, 03:56 PM | #26 |
Drives: 2017 BRZ Yellow Spec Ed 1of500
HAWK CERAMICS for your Performance Brembos
These are the HAWK CERAMICS that fit the Performance Brembos on my 2017 Yellow BRZ
Enkei RaiJins 18X8.5/9.5 +45 245/35 18 Michelein PSS I LOVE these pads, very little dust, Great stopping power for the street. Rotors smooth as glass. Had Hawk Ceramics on my 2013 BRZ Limited for 52,000 miles and they were half way worn. Those are 2011 STI center caps, had polycarbonate spacer rings made in Hungry for $5. shop here wanted $180. The lugs are from FT-86 SpeedFactory.....the frosting on the cake! Last edited by 007BRZ; 10-04-2017 at 04:04 PM. Reason: more Info correct typo |
The Following User Says Thank You to 007BRZ For This Useful Post: | Tristor (02-28-2018) |
10-05-2017, 12:39 AM | #27 |
Killed Scion
Anyone think they Wedssport TC105n in 17x9+35 would clear these brakes?
The Following User Says Thank You to MisterSheep For This Useful Post: | G_Ride (02-01-2019) |
10-15-2017, 05:50 PM | #28 |
Drives: Crystal White Pearl BRZ Limited
Anyone know if the series blue sti wheels 17x7 +48 will clear the OE brembos?
Sent from my SM-G935T using Tapatalk |
Similar Threads | ||||
2017 BRZ Performance Package Brembo Brakes Part Numbers | Veloist | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 146 | 04-27-2023 09:36 AM |
Real STI BREMBO package upgrade - DIY | Trap63 | DIY (Do-It-Yourself) Guides | 40 | 06-15-2022 09:25 PM |
Will The Brembo BBK of the Performance Package BRZ fit into the wheels of Series Blue | DaJo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 23 | 09-25-2018 05:12 PM |
To get the Performance Package or Not? Thread | Zaku | BRZ First-Gen (2012+) -- General Topics | 141 | 12-06-2016 10:04 PM |
Someone tested the Performance Package... small but SOME info at least | ~el~jefe~ | BRZ First-Gen (2012+) -- General Topics | 13 | 11-29-2016 04:21 PM |
