Old 09-15-2017, 05:32 AM   #15
churchx
churchx's Avatar
Drives: 2014 GT86
For ones wishing more camber + keeping rubber top hats (btw, including me) there is extra option of using powerflex front lca camber bushings. But i cannot tell final, if they will help much, as my current alignment result with them & cambolts is a bit non clear, with need to debug, if no installation issues.
At stock height (& stock, not KW, and unslotted struts, & stock alike top mounts (subaru group-n ones): with SPC+Whitline camber bolts front i had -2.2, adding whiteline caster & powerflex camber lca bushings allowed to get max -3.02 on left side side, and -2.55 right. Now i'm planning sometimes in future to cross-check in other shop if all is set right on right side, if -2.55 (to which i had to even out on both sides in previous shop) really was max possible there. If one has lowering springs or height adjustable coilovers, natural camber gain from lowering can be thrown in too (if on lowered with just cambolts users reported up to -2.5, then even if worst case +bushings -2.85 isn't that far from -3. I still hope for it to be possible to get -3 on both sides at stock hide too though)
Velox Top Hats! TruthfulDeception Brakes, Suspension, Chassis 10 11-22-2016 10:11 PM
WTB Top Hats SLOWrz Want-To-Buy Requests 0 07-18-2015 04:07 AM
WTB OEM TOP HATS CarNoob Brakes, Suspension, Chassis 0 10-15-2014 12:50 AM
FS: Robispec rear top hats, OEM front top hats, Scion wheel caps, OEM coin holder MyRx Brakes, Suspension, Chassis 5 10-12-2014 02:14 PM
WTB: OEm top hats FRS/BRZ rickpalace Brakes, Suspension, Chassis 2 04-01-2014 02:50 AM
