Old 09-04-2017, 04:46 PM   #15
alex.s
alex.s's Avatar
Drives: '17 BRZ Premium. Totaled: '16 FRS
Reposition your camera to get your hands in the shot, seeing where the car is can be nice for critiquing lines, but if you want to get insight into what the car is doing you are showing about 1/3 of the picture.
Things like rough binary inputs, shallow or late turn in, too aggressive or not aggressive enough, or maybe you're babying it and doing everything in your power to manage the weight transfer and the car is simply not responding, it's incredibly tough to judge without at a minimum seeing what the driver is doing.
Ill be at buttonwillow 23/24 with better cameras so I'll stick one on my helmet.
I was babying the fuck out of it compared to my last few days at buttonwillow. Slow turn in because anything aggressive at all and it would just immediately slide the front.
The more I think about it the more I want to blame the new asphalt... slurry coat, whatever. It was worse traction than even a normal street road. It was kinda like driving in light rain.
Sent from my Nexus 5X using Tapatalk
alex.s is offline   Reply With Quote
Old 09-04-2017, 05:01 PM   #16
jmark
Drives: '97 NSX-T, '18 Type R
Originally Posted by Racecomp Engineering View Post
Start with a performance alignment.
- Andrew
Alignment specs to shoot for with OEM setup plus camber bolts.
jmark is offline   Reply With Quote
The Following User Says Thank You to jmark For This Useful Post:
wparsons (09-04-2017)
Old 09-04-2017, 05:41 PM   #17
alex.s
alex.s's Avatar
which camber bolts do you have? the SPC bolts i've got (yet to install) say they do +/- 1.75*... but I've been reading about what the right settings for camber might be for this car in stock form. it seems like it really depends on the amount of grip you'll have?? more grip, more camber? i've seen some people with the stock tires setting it to -1.3*... i think it might be one of those things where you have to play with it to get the right setting for you??... i'll have them in before next track day, so I guess i'll set them to the max, -1.75* just to make alignment easier for now and try changing it later?? I've ordered some alignment toys, which should be pretty fun...
Old 09-04-2017, 06:29 PM   #18
jmark
Whiteline
Old 09-04-2017, 06:45 PM   #19
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
still had an amazing time despite the 110f weather.
What track? I ran Streets of Willow Sat. They had just applied a spray on surface sealer and ruined the track.
Lunatic is offline   Reply With Quote
Old 09-04-2017, 07:29 PM   #20
alex.s
alex.s's Avatar
yeah, i was there saturday. i saw you pitted right next to the main building, i should have said hi. nice car you've got there.
Old 09-04-2017, 07:32 PM   #21
ApexEight
Drives: 2014 Subaru BRZ Limited 6MT SSM
Are there any other practical ways to get more camber without going to camber plates? Assuming you already have camber bolts in the lower strut holes and crash bolts in the upper holes. Camber plates are pretty expensive.
ApexEight is offline   Reply With Quote
Old 09-04-2017, 07:52 PM   #22
swarb
Slotting the strut hole to be oval instead of round.
The Following 3 Users Say Thank You to swarb For This Useful Post:
ApexEight (09-04-2017), strat61caster (09-04-2017), wparsons (09-04-2017)
Old 09-04-2017, 08:55 PM   #23
Lunatic
Lunatic's Avatar
I wish you would have. Would have enjoyed meeting you. Should have come over and pitted with us.
Old 09-04-2017, 09:00 PM   #24
churchx
churchx's Avatar
Drives: 2014 GT86
More camber w/o camber plates?
Soon i plan to try powerflex front LCA bushings (PFF69-801G or PFF69-801GBLK). Will see if they'll help to get additional camber to current -2.3 w. camberbolts. Unfortunately DIY slotting here is not MOT-legal (thus i guess elsewhere may rise problems of not passing some racing class rules), and camberplates add too much NVH on local bad roads.
Ideal way for more camber would be whiteline's Com-C eccentric rubber top mounts, but on our cars those had often bearing binding problems, they tried few revisions/changes to fix that, didn't succeed, and delisted twins from compatible with them.
P.S. IIRC some of aftermarket coilovers are preslotted, eg. RCE tarmacs.
Old 09-04-2017, 10:08 PM   #25
alex.s
alex.s's Avatar
next time!
how bad was the track for you? it seemed worse than an average city street
you know now that i think about it, i'm pretty sure i sat next to you in the driver meeting, right up front.
Old 09-05-2017, 08:49 AM   #26
Lunatic
Lunatic's Avatar
next time!
The track was SHIT!!!!!!!!!!!!!! I was 4 seconds off my normal time.
Old 09-05-2017, 01:48 PM   #27
jmark
- Andrew
Alignment specs to shoot for with OEM setup plus camber bolts? Tires 225/45/R17 Pirelli P Zero AS Plus with 7.5" wide PP rims.
Old 09-05-2017, 03:00 PM   #28
strat61caster
strat61caster's Avatar
tl;dr
Max negative camber up front, should be somewhere between -1.0 and -1.8 or so, get as much as you can. If they need a number to shoot for just say -2.0, you probably can't get that much with just one set of camber bolts, but I think I've heard 2 sets of camber bolts can get up to -2.2
Zero toe front, somewhere between zero toe rear and some toe in on the rear depending on how lively you want it, maybe start with 0.2 degrees total toe in (0.1 degree in on each wheel) and see how it feels.
If it wanders too much in DD or on the freeway add some toe-in, this also applies if it's a bit too darty and nervous when driving it hard. You can toe in on front and rear. If you feel the car is dull to turn in, the back end isn't moving enough then add some toe-out. Don't go toe out on the rear unless you want something very exciting to drive to work in the morning, zero toe on the rear should be lively enough but if you feel like experimenting I think it's worth trying in the right environment (test n tune, autox, etc.).
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
alex.s (09-05-2017), jmark (09-05-2017)
Understeer Solutions? Sway Bars? Gopherboy6956 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 56 07-04-2019 04:49 AM
Not understeer, not oversteer... something else? Mazikowski Tracking / Autocross / HPDE / Drifting 15 07-25-2016 10:24 PM
Do pigs understeer? Thrustin Off-Topic Lounge [WARNING: NO POLITICS] 11 05-31-2014 10:42 AM
BRZ stock suspension understeer... what to do? mtimney Tracking / Autocross / HPDE / Drifting 40 07-31-2013 01:48 PM
03/23 Reviews --> No understeer complaints... bloomy116 BRZ First-Gen (2012+) — General Topics 19 03-26-2012 12:06 PM
