#15 |
Drives: 2017 manual BRZ
I have the whiteline insert with motul 300 and it's still more difficult to shift into 2nd than other gears. Used to grind when going into 2nd under heavy throttle or wot. Now it's just difficult with no grind or lockout. So I'd recommend doing the fluid swap and insert as well.
Sent from my Pixel XL using Tapatalk |
#16 | |
Señor Member
Have you done anything with the clutch? ie have an aftermarket clutch and/or flywheel. Or even adjusted the clutch pedal height?
1974 TA22 Celica
2013 86 GT |
#17 | |
Wes
#18 | |
Rust bucket enthusiast
Sent from my SM-G930V using Tapatalk
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block |
#19 | |
Drives: 2017 Toyota 86
For the 17 honestly I think it's your shifting method or your not use to the clutch. But if it prosists after you dive it for bit take it in to the dealer and have a tech drive with you and see if he can duplicate it. With your 13 as it's a used car I would still take it in to have it looked at as the last owner could have been double clutching it like he Shouldn't and ruined a syncro or two. It's worth having it looked at by a certified tech. Best of luck
| The Following User Says Thank You to Zentec For This Useful Post: | StraightOuttaCanadaEh (08-31-2017) |
#20 |
As for transmittions the only trans I like better than the 17 86 is the Honda S2K. That was my fav the meichanical feel, the short throw, ease of shifter movement and of course 9k rpm redline.
#21 |
Drives: 1980 corvette, 2014 Subaru BRZ
since you bought it used. There could have been a short shifter in it before, then the PO removed it to sell. In that cause the reverse lockout might be slightly in the wrong place, and you only notice it when you are in a time sensitive shift.
#22 | |
#23 |
Wes
I just talked to my mechanic, who deals with these cars on a regular basis and as soon as I started explaining the issue, he pretty much stopped me mid-sentence to say he sees this sometimes, and it's due to the OE fluid not being filled all the way, so he recommended draining it and using Motul. I'll do that and report back.
#24 |
I got locked out on 3-2 shifts on track for almost 5 years on this car until I adjusted the reverse lockout plate to the right. It seems that aggressive shifting on track caused me to go a little too far to the left and I couldn't make the shift into second. Moving the plate a bit to the right prevents this over travel.
| The Following 2 Users Say Thank You to R2 For This Useful Post: | Irace86.2.0 (09-01-2017), Ultramaroon (08-31-2017) |
#25 | |
![]() Did I miss something ... ?? Is it ma med and nap time ??....... yep, sure is ..... how did you know ....?? ![]() ZZZZZZZZ humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Zentec (08-31-2017) |
#26 |
Resident Gear Head
shift slower
the mesh point for the synchros is like 4000 RPM if your trans with the clutch pressed in is spinning freely at a 7000 RPM simulation on the main shaft with wont mesh and feels locked out. Do this too much and you will end up with a bent shift fork and or chewed up synchros. Fast shifting does not help you always win a race or accelerate faster especially if you are missing shifts. #savethemanuals
Subaru BRZ/FRS Facebook News and Tech Page
My FB Build page CLICK AND LIKE! Twitter and Instagram @misairubrz |
| The Following 4 Users Say Thank You to celek For This Useful Post: |
#27 |
The speed of the shift is not the issue. I can shift slowly and still be locked out. I'm not trying to shift between hundredths of a second. But I am to keep momentum without disrupting the cars balance during fast acceleration
#28 | |
LMGTFY
Drives: 13 FRS, 91 Miata
| Slight pull to the left on accel, pull to the right on decel | mightaswell | Issues | Warranty | Recalls / TSB | 18 | 01-12-2021 07:50 PM |
| Fender pull | pleong | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 11-29-2014 11:59 PM |
| If they Pull The Plug | exam2300 | Scion FR-S / Toyota 86 GT86 General Forum | 18 | 06-26-2014 11:59 AM |
| Datalogging 2nd gear pull? | 1Cor10:23 | Software Tuning | 11 | 04-04-2014 01:42 AM |
| Help about to pull the trigger.... | JerryMichaels7 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 12 | 02-25-2014 06:12 PM |
