Old 09-04-2017, 10:49 AM   #15
FRS Justin
Drives: 2013 Asphalt FRS
Originally Posted by carben100 View Post
So if I understand correctly, you only need to flash a new calibration if you are swapping in an ecu from a different car or using the same ecu and changing the transmission type? I'll be using the same transmission and ecu on the new engine so it sounds like it should work as is.
Are the differences in sensors between model years significant enough that this is necessary, or is it more of a precaution? The new engine has most of the sensors installed so I wasn't originally planning on swapping them all over.
By the way, I don't know how the thanks feature works on this board but I really do appreciate all the help from you guys.
I would google Subaru parts and then look up the sensors most parts will have a item fits tab and it will tell you the years the sensor fits. just to play it safe.
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Old 09-04-2017, 10:51 PM   #16
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
After 10 posts, you'll be able to thank posts
Old 06-10-2020, 01:07 AM   #17
senpai_gt86
Drives: 2015 scion fr-s
I'm looking to drop a 2016 engine in a 2015, should be a direct swap no?
senpai_gt86 is offline   Reply With Quote
Old 06-10-2020, 07:55 AM   #18
Yes it is direct. Just make sure it is AT to AT or MT to Mt or else you will need to do some parts swapping.
Old 06-19-2020, 12:28 AM   #19
senpai_gt86
would a 2014 also suffice, the 2016 was sold and now there is only a 2014 left :'( i know as far as the coilpacks are different but i doubt that'd be much of an issue right
frs
2016 frs engine. Doctordiode Southern California 3 10-18-2017 12:45 PM
For Sale 2016 Engine Transmission 2k miles six speed sokol Engine, Exhaust, Bolt-Ons 11 12-20-2016 09:15 PM
Touge.ca 2016 Track lapping events schedule - 25+ events 2016! Touge.ca CANADA 0 03-23-2016 03:43 PM
Subaru to Install New Generation of Engine Technology in 2016 86geek BRZ First-Gen (2012+) — General Topics 13 03-20-2015 03:49 PM
