#15 |
Some usa e85 is as low as 50% ethanol low e% will give you high begitive ltft
Maybe test your fuel as per here just need a craduated container in millilitres https://www.google.com.au/url?sa=t&r...6im9_2VMYtqppA |
| The Following User Says Thank You to steve99 For This Useful Post: | BuffDriver (09-06-2017) |
#16 |
Drives: 2014 BRZ sterling silver
I got a holley E85 tester from Amazon here's the link https://www.amazon.com/Quick-Fuel-Te...s=ethanol+test
#17 | |
Drives: 2016 Subaru BRZ
Use a graduated flask and the procedure in Steve99's post. Bought a plastic one I can keep in the trunk for around $6.50 on Amazon. I also went to the local feed store and bought a 65mm syringe for giving shots to livestock/pets which I pre-load with 48mm water before heading to the fuel station to accurately test the alcohol content. {Note: 50/50 propylene glycol antifreeze/water mix works too and the green dye makes it easier to read so you could carry a small plastic bottle of water or the 50/50 with the graduated cylinder} https://www.amazon.com/Pixnor-Transp...uated+cylinder
Edelbrock SC kit w/ ECUtek tune, Oil Cooler, UEL catted header, Perrin 2.5 Overpipe n Catted midpipe, 3.0 Catback resonated (all exhst ceramic coated), TRD short shifter, MTEC clutch n trans springs, Trans: Pentosin MTF2, Diff: Motul 75W90, Whiteline trans bushing, 3/4" clutch slave cyl., Ferodo DS2500 pads w/Motul 600 fluid, 17x8 wheels n 235/45ZR-17 tires
#18 |
Drives: 2017 manual BRZ
My turn for high fuel trims. Think I got a bad batch of e85? 😬😬😬
![]() Sent from my Pixel XL using Tapatalk |
#19 |
The guys with high LTFT, have you compared the images in Rom raider between your e85 and a premium tune?
The e85 tune should have timing advanced a few degrees all over and the injector flow scaling should definitely be different. If the injector flow scaling isn't considerably different, that's probably the reason for the LTFT.
2001 MR-S - long, slow, rebuild
2000 MR-S - 2zz swapped daily 2013 BRZ limited - new toy |
#20 |
Yeah. This tune is fine and this is the first time I've seen fuel trims high like this. Normally if the E% is low it goes negative. I have no idea why it's going so high though.
#21 | |
You may have developed an exhaust leak this generally results in high positive fuel trims at low rpm Or you have found some very high ethanol fuel like 90% plus Or you have a tune issue Check the injector flow scaling brz is about 171 e85 not 228 for petrol Check the di presure target tables are avout 30% higher than a petrol tune |
| The Following User Says Thank You to steve99 For This Useful Post: | Somerandom18 (09-06-2017) |
#22 | |
Sent from my Pixel XL using Tapatalk Last edited by Somerandom18; 09-06-2017 at 09:35 PM. |
#23 |
Shouldn't it be the pressure multiplier tables instead of the target tables?
#24 |
#25 | |
#26 | |
And my label is pealing off where I got a little E85 spilled on the outside of when doing a test. And it leaked too which is why I graded it 'crap' and bought a better tester. And then I noticed you mentioned 'Holly' tester which is not what I have... different brand!
| Tags |
| data logg help, e85 data logg, e85 tune help, oft help |
| Will I need another Dyno Tune if I switched headers (UEL to UEL)? | pbirmingham1988 | Engine, Exhaust, Transmission | 5 | 05-21-2017 01:15 PM |
| Switched from ST Coilovers to B8/Sportline | Roneezy | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 02-22-2017 12:11 AM |
| Switched +12 at ECU | mhiscott | Software Tuning | 1 | 07-13-2015 10:49 PM |
| switched 12v in engine bay? | blown | Electronics | Audio | NAV | Infotainment | 1 | 01-12-2015 11:36 PM |
| Switched up my BRZ lighting | alpine | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 06-23-2014 03:21 PM |
