#15 |
Also, I've had a crazy urge to build a Leh Keen 911 style Safari BRZ...am I the only one?
![]() ![]() - Andrew |
#16 | |
Drives: 2017 BRZ
I'll put in a plug for Nokian WRG3 if you're not expecting to be trudging through lots of fresh deep snow. They drive amazingly well even in warm weather, and aren't nearly so floppy and numb as most winter tires. Also, those Sparco Terra wheels seem to clear a lot, and would get the car looking a bit more Safari / go anywhere... |
#17 |
The Sparco Terras are "sold out for the season" in the color and offset I would want.
![]() Definitely interested in the Nokians...I had a set way back on my old Forester. I wish Tirereack carried them. - Andrew |
#18 |
Winter wheels on, just in time for an expected 4 inches of snow tomorrow.
16x7 +35 Enkei RPF1 (13.7 lbs!) Bridgestone Blizzak WS80 205/55/16 Overall about 5 lbs lighter than stock per corner. Stock suspension on at the moment. ![]() ![]() Went back and forth on tires quite a bit, but I think the Blizzaks will be a good fit. - Andrew Last edited by Racecomp Engineering; 12-08-2017 at 12:55 PM. |
#19 |
Plain silver center caps and different lugs are coming.
- Andrew |
#20 |
Drives: 2023 BRZ
#21 |
#22 |
Drives: 15 BRZ LTD, 05 FXT
The Blizzaks should be fun on these. I've run them in the past on AWD Subaru's and a Honda Pilot and found that they balance digging snow, and ice traction pretty well, but they suffered in the $/performance and longevity category for me.
Just got a fresh set of the new Arctic 12's to try. I'll bring them out for their debut tomorrow when we're supposed to get 6" of powder!
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
#23 | |
Also our winters are short and not that snowy, so these won't be getting a lot of miles. A good mix of ice, snow, and dry performance was the goal.Initial impressions: the 5 lb reduction per corner is noticeable. Some nice improvement there is easily felt through the steering wheel...the car reacts much quicker but it's a little odd with the new tires. The tread squirm is also noticeable. But it's not bad. Less than 100 miles on them so they may need to scrub off a little more.- Andrew Last edited by Racecomp Engineering; 12-08-2017 at 01:47 PM. |
#24 | |
I didn't see the Blizzak rebate, I've seen everyone going for the XIce 3 recently, which if you haven't had a chance to try yet, they are nice. Better on ice than the blizzaks, but not quite as balanced.
#25 |
I did get a little shit from the others in the shop for going down on wheel size on my car, but I know only true players run 16s.
- Andrew Last edited by Racecomp Engineering; 01-04-2021 at 10:51 AM. |
#26 |
Totally agreed. It's going to look great I think.
I run 15" RCG4's on the FXT in winter, 17" 04 STi BBS in the summer. Just inform people that your spine is still properly located after hitting a pothole.
#27 |
Center caps came in. These are Dorman replacement caps intended for a honda or something. They fit 16 inch to 18 inch Enkeis perfectly, and don't cost $texas like the Enkei caps. Nice and plain.
Maybe I'll make a sticker or something. ![]() - Andrew |
#28 |
Driver
Drives: 2013 Whiteout FRS
Any future plan for suspension?
| Review: Project Mu HC+ 800 Street/Track Pads | spitz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 65 | 11-30-2019 01:58 PM |
| MyNameIsKeh's Street Build | MyNameIsKeh | Member's Car Journals | 2 | 10-01-2018 12:38 PM |
| Project 2017 86 - C Street | JermMX5 | Member's Car Journals | 33 | 08-12-2017 12:38 AM |
| Tein Street Flex/Bridgestone Summers 18in/Project Kics/Morimoto HID Kit | CreinCrein | Canada Classifieds | 23 | 04-15-2016 10:06 PM |
| Project BReeZY BRZ Build*!*! | 86design | Member's Car Journals | 118 | 08-12-2013 12:00 PM |
