Old 07-24-2017, 04:27 PM   #15
Silver Supra
Hombre
Silver Supra's Avatar
Drives: 1994 Supra Turbo
Did you get an alignment yet?
You know, running bald tires (your description) does not tell you a thing about alignment, good or bad.
It seems like you now have tread to amplify movements, where you did not have it before.
Tires and brakes are the most important features of your car, so get good ones!
A Toyota Racecar A Toyota......................Because.
Anyway, should not palindrome be spelled palinilap?
Silver Supra is offline   Reply With Quote
Old 07-24-2017, 04:35 PM   #16
mrg666
pessimistic skeptic
mrg666's Avatar
Sumitomo HTR A/S P02 for just $5 more could have been a much better cheap tire. Is there a way you can return and replace?
Old 07-24-2017, 04:45 PM   #17
paiceyfan
paiceyfan's Avatar
Drives: 2014 Porsche Cayman S
Originally Posted by thatfilipinoguy View Post
New tires have to be broken in, so my guess is that since they are so new, they still have the film/release agent from when they were made. Give it a few miles of easy driving and it should be ok. I got my tires replaced a few months ago and I remember them being "floaty" on the freeway for a little bit. I just took it easy until they were broken in.
Yes!!!
I bought Continental tires recently and they were super noisy and the little 'nodules' on the outside of new tires seemed to make the car 'floaty'...sound familiar?
I would take a week or two to wear them in and they should be ok. I would not touch alignment until you have done this. Give it time.
It's not speed or the attention that matters, it is that unexplainable moment when man and machine become one! At that time, nothing else exists except the path before you.
paiceyfan is offline   Reply With Quote
Old 07-24-2017, 05:12 PM   #18
Slammillionaire
Slammillionaire's Avatar
Drives: 2013 Hot Lava FRS
Originally Posted by paiceyfan View Post
Yes!!!
Yeah I think this is gonna be my plan of action. The tires are cheap, yes, but they have been around for a long time and get relatively good reviews. If it doesn't go away in a week or 2 I'll start saving again for something better.
Slammillionaire is offline   Reply With Quote
Old 07-24-2017, 05:30 PM   #19
ZDan
ZDan's Avatar
Drives: '23 BRZ
Originally Posted by Slammillionaire View Post
Pulls to the left under gas, and then to the right when I push the clutch in.
If pressures are the same, this indicates something amiss. Do like I said, swap the rears left to right and see if pull likewise changes to right under gas and left when off the gas. If so, something is *definitely* wrong with at least one tire. And alignment won't fix it. If it's a bad tire, you should see about returning them all and getting at least a pro-rated refund, and replace with better tires.
Old 07-24-2017, 05:51 PM   #20
strat61caster
strat61caster's Avatar
Yeah, this. Tread squirm. Should go away in 500-1000miles.
Although that tire is a budget tire and probably has a really soft sidewall as well which isn't helping.
And it's pinched, making this effect worse.
Could be a lot of things OP, lots of good suggestions on what to chase down. I think a few hundred miles for the tires to break in is not unreasonable, but all the other things can be checked in the meantime. If you've checked everything and hit 1k miles and they still feel awful then I think you're stuck with what you've got.
ineedyourdiddly
Old 07-24-2017, 07:57 PM   #21
stevesnj
stevesnj's Avatar
Sidewalls are too soft.
My 2016 Build thread
Old 07-24-2017, 08:26 PM   #22
14stu
14stu's Avatar
Drives: 2014 Subaru BRZ
Put another 5psi in them to firm them up and see if that works. Tires are the only thing that touches the ground and the single biggest factor that influences performance. Tires are the one thing you should never skimp on.
Hell, members routinely offer OEM wheels and tires for $300-$400.
14stu is offline   Reply With Quote
Old 07-26-2017, 09:21 AM   #23
Slammillionaire
Thanks everyone for all of the info and suggestions. So far I've checked to make sure wheels are mounted in the right direction, upped PSI of the tires to 38 and drove a bit over 100 miles and they feel a little better. I'm hoping this will just sort itself out with a good break in.
Old 07-26-2017, 09:44 AM   #24
ZDan
ZDan's Avatar
Drives: '23 BRZ
Does it still pull left on accel, right on decel? If it does and pressures are the same, swap rears left/right and see if the pull changes direction. If it does, bad tire, replace it. Or all 4 with a more appropriate make/model.
Slammillionaire (07-26-2017)
Old 07-26-2017, 10:47 AM   #25
bhmax
Drives: 13 BRZ, 17 Focus RS
Also curious about the accel/decel pull. The only time I've had this I had the same model tire on the rear but each were made in a different country. Swapped sides to verify that the pull changed directions. Measured and one had a larger circumference.
bhmax is offline   Reply With Quote
The Following User Says Thank You to bhmax For This Useful Post:
Old 07-26-2017, 11:40 AM   #26
Slammillionaire
Will take a look at this today and get the tape measure out. Thank you!
Old 07-26-2017, 11:49 AM   #27
bhmax
To clear any confusion, by "same model tire" I meant some Bridgestone S001 tires that I had, but one was made in Japan and the other was somewhere from Europe.
Old 07-27-2017, 11:29 AM   #28
stevesnj
stevesnj's Avatar
38psi? Too high for the vehicle weight, tire will wear in the centers
TRD Springs and Sways Shark_Bait88 Want-To-Buy Requests 0 10-25-2016 01:03 PM
Need some help...Sways & Springs Lebby83 BRZ First-Gen (2012+) — General Topics 2 06-08-2015 10:42 PM
No sways BadCompany235 Tracking / Autocross / HPDE / Drifting 13 08-20-2013 02:05 PM
Buying sways.. _F-R-S_ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 28 11-14-2012 11:07 PM
