Old 09-10-2019, 07:02 PM   #15
steve99
Originally Posted by FR_STEEZ View Post
I was looking at the throttle parameter and accelerator parameter. ill slowly push the pedal in and I wont get any response until I get out of that dead zone.. but when I look at the pedal parameters in the tunebot section of my oft you can clearly see its getting a signal when barely any pressure on the pedal. I have no idea how to fix this dead spot
If your car is NA on petrol with stock intake, try flashing back stock tune and see if it goes away
Old 09-11-2019, 08:06 AM   #16
stacyu18
Drives: 2014 subaru brz
thanks for posting this i just reflashed my car for 700cc injectors and i have a hugh dead spot from 500 to 1100 just sent my tuner the email to see if there is anything he can do
stacyu18 is offline   Reply With Quote
Old 09-11-2019, 10:24 AM   #17
FR_STEEZ
Drives: 2017 toyota 86
I’m on the stg 2 e85 map
FR_STEEZ is offline   Reply With Quote
Old 09-11-2019, 06:54 PM   #18
steve99
Ok well flashing to stock no go till your on petrol.
Can you​ post a log of tune with
  • Engine Speed (rpm)
  • Throttle (percent)
  • MAF Voltage (volts)
  • Engine Load (g/rev)
  • Ignition Advance / Total Timing (degrees)
  • AFR
  • Commanded AFR
  • STFT (percent)
  • LTFT (percent)
  • Oil Temp (F)
  • CL/OL / Fuel Sys Status (2 = CL, 4 = OL)
  • IAT / Intake Air Temp (F)
  • IAM / Ignition Advance Multiplier
  • FLKC / Fine Learning Knock Correction (degrees)
Please post log to www.datazap.me
FS: Cusco Accelerator Pedal mb_ Interior Parts (Incl. Lighting) 5 08-21-2015 06:46 PM
Accelerator Pedal Blu-by-U Scion FR-S / Toyota 86 GT86 General Forum 14 03-23-2014 11:59 PM
WTB: Cusco Accelerator Pedal BeRZed Want-To-Buy Requests 0 03-03-2014 03:12 AM
Pedal adjustments supramkivtt2jz DIY (Do-It-Yourself) Guides 3 03-31-2013 06:56 AM
Pedal Adjustments? djliquidsteele Engine, Exhaust, Transmission 3 06-09-2012 11:43 AM
